AMD - How To Overclock The Official Way Using Afterburner + Step By Step Overclocking Guide + Comple
27 Apr 2012
Northern Ireland
Tried this myself and it didn't seem to unlock voltage control and my overclocking range is lower than before :\
7 Feb 2003
I used this method in the past adding /xcl to the AB shortcut to allow full unlock
But I found that I had to change User Mode to Kernel Mode to get it to work for me
Caporegime
OP
12 Jul 2007
United Kingdom
I just did it again, from scratch. Didn't touch the cfg. Install afterburner, run it, restart at prompt, install the clock change patch, added the /xcl ran the shortcut, deleted /xcl, restarted pc.
Unlocking voltage in settings is the last thing you do!!
27 Apr 2012
Northern Ireland
That's exactly what I did, as well as installing this as per instructed http://www.sendspace.com/file/r7jys0
27 Apr 2012
Northern Ireland
I think ive discovered the problem.
Ok try this. I managed to replicate it not working.
Try placing these two files in your windows/sys64 folder, then do the guide. I don't think the clock control patch is needed, but these files are instead. Let me know how it goes and ill update the guide.
http://www.sendspace.com/file/oh85by
sys64? Didn't think such a folder existed, only system32. Can't seem to find one anyway.
Caporegime
OP
12 Jul 2007
United Kingdom
Found it now. So just dump them in loose, no need to place them in any specific folder?
Then just try the Afterburner installation again I guess?
Yep. I'm convinced this will work, if it doesn't ill buy you a beer and we can reminisce about the good old days. Hopefully borely gives it another bash as well.
Caporegime
OP
12 Jul 2007
United Kingdom
I know even in just unlocking Afterburner on later versions of CCC you need 2 .dll files extra I take it these are the ones?
Regards
Yes, these are the two files. I guess thats why its not working, because you guys dont have them.
To be honest i forgot i had them installed as i added them to enable my 6950 un-official overclocking in afterburner 6+months ago so the files have been sitting in my windows folder all this time and hence, it worked first time for me.
Caporegime
OP
12 Jul 2007
United Kingdom
Tried it and still no voltage control. Looks like I'll just have to use Trixx again.
The plot thickens. If i remove those files then the /xcl command does not work for me and afterburner won't open till i remove the /xcl.
Just install afterburner on its own and unlock voltage control. You should be able to do that, if you can't then something is wrong.
We really need someone else to try this to get a wider spectrum.
Maybe you do need the clock control patch.
27 Apr 2012
Northern Ireland
Done both of those things, and no voltage tweak. Just doesn't seem to work for me, going to go back to Trixx as it worked for me.
Caporegime
OP
12 Jul 2007
United Kingdom
It seems the clock control file adds the files automatically.
Something must be wrong with your setup if you cant even unlock voltage control in afterburner. Thats a basic feature that you can enable after install without touching anything.
Which ati drivers are you using?
EDIT
Confirmed working for other people
http://forum.guru3d.com/showthread.php?p=4288963
