Best 7950?
OP
20 Jul 2012
Manchester
Yeah it seems the 7950 Vapor-X is voltage locked - at least the one I have is.
So anyone who buys one should be wary of this.
I asked Sapphire about it and got this as a reply:
"Dear Sir:
We recommend you use CCC of power control function."
:rolleyes:
6 Feb 2003
Edinburgh
"Dear Sir:
:rolleyes:
Are you going to RMA/DSR it like the last one then?
14 Nov 2007
15 Mar 2011
Eden Prime
3 Jan 2011
Tipton
It's silent even at 1115Mhz :)
Well, of course it isn't silent :p But I can't hear it over my case fans.
Lol I like quiet too.
Slight disappointment for me as I noticed last night that Afterburner max core setting is 1100 with my TF3.
Real shame because I think it would hit 1200 with a touch more voltage (although I suppose I don't really need that).
OP
20 Jul 2012
Manchester
Caporegime
17 Mar 2012
ARC-L1, Stanton System
http://forums.overclockers.co.uk/showthread.php?t=18431335
Try this - it lets me go to 1200 :)
I got it wrong, it actually increases my max clock to 1710 :p
Good Grief.... Don't run clocks that high.
Unlocking xtreme volts / clocks in MSI Afterburner is for those who bench on liquid nitrogen
For every day use keep the extreme volts / clocks locked and use the standard overclocking. using extreme will fry your card in weeks or days.
1200Mhz is about the most you should run for every day use, if you can't get that on the voltage adjustments you have without unlocking xtreme then your not going to have 1200Mhz. :)
