7950 Temps When 1100 core
25 Nov 2011
The KOP
16 Mar 2012
Chelmsford,Essex,UK
On my 7970 @ 1200core/1650 mem 1.212v I hit low 60sC that using Afterburners stock fan, but my card is the windforce with 3 fans so pretty well cooled anyway. Long as you steer clear of the crap auto that seems to be on 33% all the time you should be fine.
30 Mar 2010
Under The Stairs!
That was out of game. I forgot to click to show max on speed. I have the fan set to auto ATM.
Doesn't matter, it should still be spinning faster than 20%@75c until the temps reduced, leading me to believe your fans not spinning up properly.
Unless of course you can hear the fan ramp up, as after 60c, it should be a pretty audible ramp up at least.
75c isn't a matter of concern either as Matt pointed out, but get Afterburner and use the OSD to show temps and fan speed in game, or log with GPU-z to make sure.
OP
25 Nov 2011
The KOP
You reading it wrong mate. Am showing Max temp on them images, the card had already spined down.
Thats why you seeing 20% temps now are 28C idle.
OP
25 Nov 2011
The KOP
Could you post image of Afterburner fan profile please.
OP
25 Nov 2011
The KOP
Shouldn't worry too much, 75c isn't that hot.
You could always set a custom fan curve, 80% fan speed must do your nut in though?
I have headphones on but yes I dont like it even tho I can't hear it when gaming. Take headphones of and PC sounds like its about to take of lol.
Am new to setting a fan speed and am not sure what I should use :( My card is a Xfx HD 7950 Double dissipation.
Am worried if I setup a fan speed it will send temps much higher.
21 Sep 2009
London
The XFX DD cooling has never been rated that good tbh, and in a few reviews of the 7970, the DD version was found to have poorer cooling ability than the stock reference cooler. I would invest in a Arctic Cooling Accelero unless you mind having the sound of a jet engine in your case everytime you game ;)
OP
25 Nov 2011
The KOP
:( I though theses cards ment to have one of the best cooling designs. Are they hard to install? Take it you loose the warranty?
27 Feb 2012
Just set up a 1:1 curve.
30 Mar 2010
Under The Stairs!
Not really, if you use thermal tape, it will take up to an hour if you want the heatsinks to stick on properly.
If you use the included glue, you need to leave it to set overnight.
But, if the DD has a separate cooling plate for the vram/vrm's, then it will only take about 10 mins tops as you just need to screw the AC heatsink on.
With XFX, yes, so you would just use the glue.
OP
25 Nov 2011
The KOP
Thanks dont think I really want to be doing that. But might look up some youtube vids, review on installing and I maybe try it.
