Mega bucks to be saved today!
Intel 330 Series 180GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail @ £99.98 inc VAT
Get Fast. Play Fierce.
Faster game and application loads, less lag, smoother visuals.
Stay ahead of the competition when you level up to 6.0 gigabits per second (Gb/s) performance
New Level of Performance
- Capacity: 180GB
- Controller: SandForce SF-2281
- Maximum Read: 500MB/sec
- Maximum Write: 450MB/sec
- Max I/O Per Second (IOPS): 33000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 years
Only £99.98 inc VAT.
ORDER NOW
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black @ £299.99 inc VAT
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Display Colors: 16.7M
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
Only £299.99 inc VAT.
ORDER NOW
- Capacity: 180GB
- Warranty: 3 years
ORDER NOW
Features:-
- HDCP Support: YES
ORDER NOW
