5.1 vs 7.1 Gaming Headset...
7 Sep 2012
Lancashire, England
I'm looking for a reasonably priced gaming headset which must have surround sound... Is the difference between 5.1 and 7.1 very noticeable? Are there actually any games that make full use of 7.1 sound?
I don't really want to spend more than £80 and have mainly been looking at the Corsair Vengeance 1500, Roccat Kave 5.1 and Plantronics Gamecom 780 headsets. Does anyone know if the Chinese brand 'Somic' are any good? They certainly seem to offer a nice range of surround headsets :cool:.
Please feel free to recommend something, cheers ;)
OP
7 Sep 2012
Lancashire, England
I'm not bothering with the Plantronics Gamecom 780 as i've just found out it's 'virtual' surround and not true surround :rolleyes:. I'm looking for either a 5.1 or 7.1 'true' surround headset for no more than £80... Not bothered about branding as long as it's good quality (i'm not bothered about audiophile quality either, hence the reason i'm not spending £££'s on a headset ;)).
12 Feb 2007
Bishops Waltham
I had the Roccat Kaves before and they're pretty good, only thing I would say is that after a couple years of use the headband became weak and snapped...
I've since upgraded them to the Razer Tiamat Elite 7.1 headset... They're very good, but tbh so far (i've only had them a couple days though) I'm not sure I can really tell the difference between the 2 and in having 7.1 over 5.1.
OP
7 Sep 2012
Lancashire, England
I'll probably end up getting the Corsair Vengeance 1500 headset... Reviews seem good and it's 7.1 (although there's probably no real difference over 5.1, but they're within my budget).
5.1 and 7.1 is a gimmick in headphones.
Please look into getting yourself a real pair.
I have a 'real' pair for listening to music (Sennheiser HD 600 :)), and i personally don't think 5.1 (or 7.1) headsets are a gimmick when it comes to gaming... I borrowed a friends 5.1 headset a while back and was quite impressed (I think they were Tritton branded, i can remember them being white).
It's not a gimmick as long as they have well placed seperate speakers for each channel (none of this virtual surround rubbish) ;).
19 Dec 2010
You have a pair of Senn HD 600 and are looking for another headset for gaming?
Are you using onboard audio to drive the HD600 while gaming or something? I know the HD 600 doesn't have the widest soundstage in the world, but combine with some of the "virtual" surrounds like dolby headphone or cmss3d it's positional audio should be as good as any of the 5.1 headsets and it should sound better too!!
OP
7 Sep 2012
Lancashire, England
I don't use my HD 600's with the PC (the onboard Realtek ALC892 won't do them any justice anyway)... I know i can use Dolby, CMSS3D or Rapture3D software to create 'virtual' surround sound, but it's just not the same as true surround using seperate channels and multiple speakers in the headset. The HD 600's are fantastic when it comes to music, but i'm pretty sure they're not designed for gaming or positional audio.
Is it best to get a USB headset (i think they have a built-in sound chip) or one that connects to the seperate audio outputs (front, rear, center etc...) on my motherboard?
19 Dec 2010
Well, you made your mind up, but, a good stereo headset should give just as good positional audio as any 5.1 headsets. Actually they will give better positional audio.
Plug in your HD600's into your PC and go listen to this
https://www.youtube.com/watch?v=QmL-YRxC6Y8&hd=1
IF I was you I would buy a sound card that can drive those headphones. The new creative Z is in your budget of £80 and has a 600Ohm headphone amp, so will open up those HD600's a lot :) Buy it, try it out and return it under DSR if you aren't happy.
OP
7 Sep 2012
Lancashire, England
https://www.youtube.com/watch?v=QmL-YRxC6Y8&hd=1.
I'm not sure how a stereo headset could possibly give better positional/surround audio than one with dedicated speakers for each channel? I must admit that Youtube link sounded brilliant as far as Youtube quality goes (it did have a slight echo and the rear sound was slightly weak - but maybe it's just me).
I think i'd prefer the X-Fi Titanium or a decent Xonar card over anything that uses the Sound Core3D chip... I used to have an Auzentech X-Fi Prelude a few years ago, but i ended up selling it as i never really listen to music on my PC and the Windows 7 x64 drivers at the time were a bit shoddy for gaming (i got it cheap anyway as it was used and actually made a small profit by selling it on ebay :D).
The onboard Realtek ALC892 (7.1 THX certified) does an admirable job when it comes to gaming, albeit i'm using an average pair of Creative Gigaworks T20 speakers (which are still quite good for their size)... I'll look into getting another dedicated sound card if i have space next to the massive GPU in my Micro-ATX gaming rig!
19 Dec 2010
Do you have a headphone amp with an optical input? Or how are you listening to music on the HD 600's?
IF you do have an optical input on the headphone amp, then connect your PC to the amp using optical and try that demo again. It sounds weak because the computers onboard audio can't drive those headphones right at all. :)
Basically, you have only 2 ears, your brain works out distance based on stereo. HEadphones with a good soundstage will be as good or better than any 5.1 headset. Some people would even go further and say if you have a great pair of stereo headphones than you don't even need any virtual surround like cmss3d or dolby headphone.
Well, about the sound card, don't base the Z on the recon3d, they are two entirely different animals. The Z sounds a lot better than the Titanium according to a user on another forum who compared the two. And I know that the positional audio on the Z is a better than the dolby headphone on the Asus DG and the cmss3d on the creative xifi fatality.
I moved from the same realtek alc892 chip as you have to the Xonar DG. Didn't realise how bad the sound was until I changed. :)
19 Dec 2010
Oh, sorry you mentioned the Corsair vengance 1500 earlier in the thread. I am not 100% sure, but I think it uses virtual sound through it's USB card? Not sure if it has the true surround sound you are looking for. I think the Roccat Kave might be what you are looking for though.
OP
7 Sep 2012
Lancashire, England
I don't think USB has anything to do with real or virtual surround (i could be wrong though?). If i get another sound card then it'll have to be PCI as my GPU is blocking the small PCIe x1 slot and i don't want to use the other full sized PCIe x16 slot (otherwise it will reduce my GPU's PCIe slot to x8)... I don't think there's any difference between PCIe and PCI when it comes to sound cards anyway.
The HD 600's do sound great on my PC, but unfortunately they don't have a mic (i prefer the mic to be attached to the headset).
What PCI card would you recommend?
19 Dec 2010
The corsair 1500 is a usb headset. It has a sound card that provides the audio to the headphones. I think it uses virtual surround. Maybe someone who has one can correct me :)
You are right, there are no differences between pci and pci-e. Just that pci cards are starting to get a bit thin on the ground!!
21 Feb 2004
London
Just heard that youtube video, wow, amazing. Got me listening to more vids, this is another with some good 360 degree moving sounds and also includes the above barber shop experience.
https://www.youtube.com/watch?v=oPTa4_HrPhs&feature=related
Based on melmacs advice I'm going to try gaming in stereo and leave my 5.1 Tritons aside (which I think sound great BTW) and hear the difference. Obviously this means setting games to run in stereo rather than 5.1.
19 Dec 2010
Yeah, that demo really does sound amazing. I will give your link a listen to later on, currently listening to some tunes, don't want to ruin my ambience :)
what headphones do you have Herman? And what sound card? I set all games to 5.1 and set the windows control panel to 5.1 as well. I only change to headphone my creative z control panel.
21 Feb 2004
London
No fancy headphones here, just good old in ear sennheiser cx300II. Also on board sound on my mobo - very basic I know!
If you use stereo headphones then why do you still set your games & windows to 5.1? Presumably that would output sound to each analogue output and you will miss out on non-stereo sounds (ie rear, centre, subwoofer), or have I misunderstood something?
19 Dec 2010
I think you are in for a disappointment :( Not sure how good the sound stage is on those headphones. hehe sorry a funny analogy just crossed my mind there. I have just convinced a man of the advantages of mobile phones but he has only access to two cans on a piece of string :D
PLease try out a few games, try setting the sound to headphone out and then try setting to 5.1 and see which gives you the best result. Don't set the game to stereo, set it to headphones or 5.1.
But as I said, the headphones aren't the best. Your tritons will probably sound way better!!
OP
7 Sep 2012
Lancashire, England
Ok, if i get the Roccat Kave headset then i'll need a splitter so that i don't have to keep swapping speaker and headset cables :rolleyes:. Do all Xonar cards have a header for front panel audio? Also, do all Xonar cards support 'Dolby Headphone' incase i decide to use my HD 600's? There seem to be many variants with different features!
Cheers!
19 Dec 2010
yeah, it's a confusing mess sometimes!! Not all xonar cards have the front panel audio connector, the DG is the only one under £100 with a headphone amp and it has a front panel connector too.
It's a pain switching between speakers and headphone all right, it's part of the reason I went for the creative Z. But, for you, I think you need to decide if you want to go with the senns and a sound card or to get a 5.1 headset? I think you are too focused on this "true" 5.1 surround thing.
Going with a USB headset might be the simplest and easiest thing for you to do, so maybe your choice of the Corsair vengance 1500 is the right one. You could leave these plugged in and use your speakers as well. Since you don't listen to music on your computer audio quality isn't as much of a problem. And you will probably more than happy with this.
Of course there is another option :) Just keeping you on your toes!! Get the Xonar DG and an external headphone amp which has an optical input. That's why I was asking what you were using to drive the HD600s. You can output the dolby headphone through the spdif to the external amp. This option means you can leave speakers and headphones plugged in at the same time.
OP
7 Sep 2012
Lancashire, England
I use my HD 600's with my Denon setup (which does have optical)... But it's downstairs and my gaming PC is upstairs! Do you think the cheap Xonar DG will be a noticeable improvement over the onboard Realtek ALC892? It's seems a good price and like you said, it has both a headphone amp and front panel connector. It also supports 'Dolby Headphone' which does seem better than i initially thought... I'll just have to put up with a clip-on mic :).
Is there anyway to get a Dolby Headphone utility so that i can properly test it with my onboard audio? Or does it come as part of the Xonar driver package?
