Any builders/architects? I'm trying to avoid my roof caving in..
Caporegime
25 Jul 2003
FR+UK
This is my loft as it currently stands, if you can pardon the atrocious diagram.
Side view:
Essentially in blue is a sort of A frame, that doesn't really appear to be doing anything. It's secured to some floor joists, but at the top doesn't appear to be massively safely secured - eg its not support much of the roof weight at all.
There are two large joists running the length of the roof below the horizontal "a-frame" beam, and it seems to be these that the roof joists are taking their support from.
I'd like to make the space more useable, so want to take the Aframe out, and am wondering if adding two more supporting joists higher up will suffice - I've had a builder look at it and say that it will, but I just want to run it by the DIY experts on here and see what they think:
(roof face head on view)
As I'd like the roof to still be standing after taking it out :).
Caporegime
OP
25 Jul 2003
FR+UK
When I say I want to take the Aframe out, I'm more than willing to have it taken out ;).
Have already checked with building regs, as long as I'm not having the roof facade altered or made higher, it won't need permission/notification.
Caporegime
OP
25 Jul 2003
FR+UK
Are you sure they didn't just say you don't need planning or specifically building reg?
They said we do not need either because we are not adding a bedroom, but I understand what you're talking about now, I've quoted the wrong thing :p.
Yes we will likely need building reg approval then. Bugger.
Caporegime
18 Oct 2002
You want a qualified builder to look it over, far more than some advice from this forum with bad pictures.
Buildings can be made incredibly differently with the same outwards appearance, or built badly and therefore need other things doing to make safe, who knows.
Not in all situations but, a lot of pitched roofs the bits between the roofs are less about support and more about preventing lateral force, the support comes from the walls but pitched roofs, well think of two cards leaning against each other in the same shape, the bottoms of the cards want to move outwards. So the wooden structure inside is to keep them together, while the weight of the roof itself is loaded on the walls.
No matter how the roof is built, this is a job for a professional builder, and having a professional tell you what you can safely do.
1 Mar 2010
5 degrees starboard
Removing the internal truss members will alter the loads on the rafters and walls. One option would be to run steel purlin members wall to wall under the rafters at the same height as the horizontal blue members. The upper purlins could then support a ceiling level and the lower ones vertical walls. You would need four steel beams (possibly large twin timbers to span the length of the roof. Built in at the gable walls. You have two of these members but they probably have lateral restraint from the horizontals in the frame.
This is a structural engineering calculation as you have to consider not only roof dead weight but environmental loads, wind, snow etc. to the current design codes. You also need to consider changes to the support at the gables, deflections under load and additional or changed support to the rafters on the wall plates. The A frame may well support the ceiling joists below.
A builder will tell you what is possible but for building regulations (not planning approval) you will need calculations submitted.
I am a civil design engineer by profession.
Tea Drinker
Don
13 Apr 2010
Sunny Sussex
You need a structural engineer to design steel beams for you, last one I used cost £250 for a visit and a sketch, it's pretty simple and an every day conversion.
If you want it to be liveable you would need building reg approval for things like fire between lofts (assuming it's semi or terrace) and also any stairs you put in will need to be signed off, head height, width etc, you won't need to if you're going to put your choo choo trains on a bit of plywood.
Caporegime
OP
25 Jul 2003
FR+UK
We have had a builder look at it, but from the sounds of it a structural engineer needs to be booked as well. I guess it isn't the kind of thing you can do on the cheap!
20 Sep 2012
Romsey, Hampshire
If you are looking to open the space up then steel joists will be the way to go. I guess you will still be using a ladder to access it? You will only need to keep the building regs people happy if you are converting it to a living space and will require fire doors everywhere and a mains powered integrated fire alarm system with sensors in every room.
Caporegime
OP
25 Jul 2003
FR+UK
Ideally we'd like to use it as an office. It won't however be a bedroom; does that qualify as a "living space"? If so we might can that idea and open it out for better/easier storage.
