for multi monitor setup, i prefer windowed view. in game you bring up a new view with the [ key, undock it with a right click and drag it across to your other monitor. this way you can have a wide virtual cockpit or a cockpit in one and radio controls on the other.
Guys I need some help. I have an i7 rig. I've tried all sorts to get it to use more than one core. One core is at 100% and one other is used abit.
I have played with the affinity and still nothing.
Would really appreciate some help or advice ?
Is hyperthreading off?
It's on in the bios. If I switch this off wont it affect other games like bf 3?
Sorry for the newbie question. I presume hyper threading just gives me back my actual 4 cores ?
I think the hat switch/TrackIR or whatever you use to change your view only affects the current window. Thus not the solution for multiple views.
So a solution does not exist for this kind of "virtual cockpit" over multiple monitors?
