Soundproofing in a rented house?
22 Aug 2010
On the Wagon-East Angular
No no no. You said in post 3 that 'you can't get that kind of reproduction with the type of headphones I can afford', intimating that there ARE a type of headphone that will allow you to do this.
Links to those with prices please.
26 Mar 2003
So what stops you bouncing all audio to just one set of cans?
Because its impossible to mix bass freqs on cans, the representation is disproportionate. What sounds great in cans will sounds terrible on a hifi. You need to use reference monitors with a flat freq response.
Permabanned
OP
9 Mar 2010
Fabric Nightclub, London.
Look, as I said, when you mix, you have the master audio (what you hear from club speakers) coming from one audio out. To be able to beatmatch, and thus mix effectively, you need to use the headphone out on your decks to monitor the incoming track, without it playing through the main out. This is why it can't be bounced to one set of cans.
Permabanned
OP
9 Mar 2010
What did you eggs-pect This is GD :p
Show some eggspect everyone
Okay, I'm done. I think I've honestly eggshausted my brain of words I could use now :o
Time for some Fresh Air and
eggsercise
Eggsellent use of puns there :)
And listen to the person who has studied audio tech:
As well as my previous post.
1 Apr 2004
That's a good answer. Thanks.
Permabanned
OP
9 Mar 2010
Also, read this:
26 Mar 2003
I wish you luck dude.. but the life of someone who makes noise for a hobby/profession isn't easy when it comes to practising and all that. Looks like I've always had luck with neighbours.
22 Aug 2010
So you state as fact that there are headphones that can do what you want, but you also agree that there aren't headphones that can do what you want :confused:
Make your mind up :rolleyes:
You stated that there are no headphones that you can afford that will do this, yes?
28 Nov 2004
9th Inner Circle
Can't be done. I doubt it could be easily done if you had money to throw at the problem. As for egg cartons, forget that idea. Won't do anything.
The answer is: Headphones, do it during social hours or STFU I'm afraid. :)
1 Apr 2004
You have two ears. I got an answer.
Permabanned
OP
9 Mar 2010
I think you are the one confused here...
The answer is: Headphones or STFU I'm afraid.
Yeah, I'm starting to give up on the idea of eggcartons.
Might have to try and rent some studio time elsewhere.
1 Apr 2004
Yep, this confirms that you have absolutely no idea.
Ah sorry Shayper. I didn't mean to get at you tonight.
I respect that you worry about your neighbours.
You do have two ears - no more - so what you hear is what you hear.
No matter how many decks and mixes you have - you are stuck with owning only two ears. A grand set of headphones will cover them.
