**Official Unigine Valley Leaderboard**
Caporegime
18 Oct 2002
Ireland
That's a bit low isn't it? I'm running 2x6950s at 6970 speeds and I get a higher score than that.
Does seem a bit wonky for some reason, might have to run it again to see if anything changes.
ED: afterburners reporting only a 60%ish load on each gpu at the minute, so im losing quite a bit of performance.
Man of Honour
21 May 2012
Dalek flagship
New score
HD 7970 x 2 @1270/1850
3970X @4.9
14 Aug 2007
York, UK
1635 score with 1125/1575 overclock on a reference 7970 seem low to you guys?
Extreme HD Preset
Driver: 13.2 beta 6 (driver swept)
Temps: 73c
Voltage: 1050 (stock) to 1175
So i did a clean install of windows 7 and know im getting decent scores.
I managed to get to 1200/1600 @ 1225 voltage, temps 76c and a score 2067
Im thinking if getting a artic accelero xtreme cos the noise from the reference fan is ridiculous. How much further you reckon i could push it with the xtreme?
14 Oct 2003
South Derbyshire
Right then disabled the bottom 2 cards (pulled the power out :D)
125 strap + 105 Host frequency= 130mhz BCLK+PCIE x 38 cpu got me 5000mhz
3930k @ 5000mhz
GPU @ 1390mhz/1950 1.38v (artifact central)
Caporegime
12 Jul 2007
United Kingdom
I'm familiar with BLK on sandybridge but the strap (unless locky is referring to a jock strap) not so much. I vaguely remember a fsb strap from my socket 775 days but that was so long ago its since been forgotten.
3 Jun 2012
But does it allow for a more stable GPU clock?
because at the moment im sure you all have the same issues as me when you get to 1300+ that the Thing is artifacting like a disco show.
Thats why my max score is on a 1260 overclock as that's stable and no artifacts.
