**Official Unigine Valley Leaderboard**
23 Feb 2013
Thats cute, when you already have a chart of cheaters ;)
It's not as if I hid the fact it was a cheat score lols.
Why do you act like this, is that a normal behavior for these forums?
You hid the fack on OCN, I caught you. Can you point me out the cheaters?
I'll re-ask, what was your point of doing so?
14 Oct 2003
South Derbyshire
CYPER for one ;)
No I don't usually act like this, I was proving a point to CYPER that cheat scores could be submitted anywhere. The argument was between me and him and his ridiculous score.
we asked him to video his bench run (and GPU settings) It didn't need to be exact, but close, but he declined.
23 Feb 2013
CYPER for one ;)
No I don't usually act like this, I was proving a point to CYPER that cheat scores could be submitted anywhere. the argument was between me and him and his ridiculous score.
Have a nice day.
If you want to post your score with Tri-Fire, I will be glad to add you ;)
14 Oct 2003
South Derbyshire
Scaling not so good yet, expected you to be over 6K with two running. The AMD cards anyway seem to scale close to 100% in XFire.
I wouldn't say 100% but close
with the crossfire profile I use, I can get 95% average scaling throughout the benchmark, most of the time it is at 99% but there is a few dips, they occur when you get the large overpass before it hit's the tress, I will get the exact seen number when I next do a run.
23 Feb 2013
I hope AMD will release driver soon with Valley Application Profiles.
Without the Optimize 1x1 Crossfire mode:
Dual cards: 100% scaling (and a bit less)
Triple Cards: 66%
Quad cards: 50% scaling
So if I don't do the fix on my rig, my Quadfire score seems like a Crossfire score. :eek:
Very annoying.
Locky, which Crossfire Mode are you using?
14 Oct 2003
South Derbyshire
Triple Cards: 66%
Very annoying.
I use optimise 1.1 for crossfire and AFR for trifire, but tbh there isn't much difference (few points)
Permabanned
15 Oct 2011
Nottingham Carlton
kamz temperatures are not a problem in my case with external radiator and ek Full cover block. Maximum i had so far was 53 after 4 hours of playing crysis 3 :p
I should see how far i can push them memories on my VTx 7950 :D Maybe next month i will flush my cooling system and add another 120mm rad between cpu and gpu :)
Still best 7950 on ocuk :D
7 Jun 2010
Sussex
1080P High 4xAA
i5 2500K 4.3Ghz
GTX 480, 900 core 1900 Memory.
1080p Ultra
GTX 480 900 Core, 1900 Memory.
Man of Honour
9 Jan 2007
Metropolis
Update:
Score 3092
Win 8
GTX Titan @ 1007/1567/1046
3970X @ 4.6
26 Jan 2005
In........cognito
7970 @ 1274/1823
FX8350 @ 4.8ghz
I can't go over 1274Mhz without it artifacting. The guys with 7970s that are getting core clocks over 1300Mhz, do they have access to higher vcore? Max vcore in AB is 1.30v, reading 1.28v in HWiNFO.
3 Jun 2012
7970 @ 1274/1823
FX8350 @ 4.8ghz
Go higher anyway, The guys who are going far have all got bad artifacts.
