LackRack v2
2 Jul 2004
East Midlands
Hi Guys,
Not sure whether to put this in the projects forum or here but figured as it only took an hour to put up it wasn't really much of a project so I present the LackRack v2.
Total cost was £17 not including screws and petrol. The unit will take 7u's and I've personally rated the rack up to 91 kilo's (I sat on it in the shop to test its weight bearing properties :D) It consists of:
1 Ikea Lack Table £5
8 Ikea Bygel 55cm rails at £1.50
The rails are perfectly spaced to interlock with the server's inner rails so you can pull the server out and work on it while still in the rack (Once i've bolted it down) this was quite important while still in its present position as man handling servers in the loft is not the easiest. Currently it is supporting 45 kilo's of server.
Front:
Side:
Populated in its temporary position:
Thanks for reading
B
12 Jun 2012
West Yorkshire
Are they just screwed in? thinking of something like this although im worried how many times i can screw/unscrew before the hole gets messed up.
Looks pretty cool.
DRZ
DRZ
2 Jun 2003
In the top 1%
Depends where your patch panels are really.
Kimbie
Well if your server rack had a patch panel then it is probably because you're doing EOR switching - so a) there wouldn't be any switches in the rack and b) the patch panels will be where they should be - at the back :p
If you are doing TOR switching (like the OP) then you'd expect your switches to be at the back where all the cables are...
Comms racks are different of course, but you don't see servers in any comms rack run by someone sensible ;)
10 Nov 2004
Expat in Singapore
Not all racks have easy access to the rear especially in a non-enterprise environment.
My patch panel and switch are at the front, as will be my Infiniband switch when it arrives. Putting it at the back makes my life a lot more difficult if I need to change anything.
I also like to impress visitors with my flashing lights ;).
RB
12 Jan 2006
UK
Think you need to relax a little DRZ. It's a switch at home not a data center.
OP
2 Jul 2004
East Midlands
At the moment it is in a temporary position, it certainly won't be staying in the loft during Summer. With regards to the switch, part of it is flashing lights :D the other part is access, at the moment my office upstairs has no wired access to the router downstairs (To be replaced this week with a new custom built box but thats a new thread) which will eventually go in that rack, I just patch a cable from there to the office when i'm working and I can do it without getting the step ladders out, and it keeps the wife happy because i'm not crashing about in the loft.
Its more just a proof of concept/ home project than anything professional.
Thanks
B
28 Sep 2008
Britain
RB
This, where most wall mounted rack cabinets in SME's are, well, wall mounted, I'd love to see DMZ access his patch panel at the rear, when it's shoved up against a wall :)
11 Jun 2003
Sheffield, UK
Looks pretty cool.
I'd imagine you could drill out and glue in some metal studs with thread (or go ultra cheap and just some regular nuts with a bit of space behind), buy a pack of thumb screws and have it a little more durable (maybe with a metal strip screwed to the back of the front legs to replace a bit of the structural strength removed from drilling). Would add about... £5/10 to the project :D
