doh, forgot to change the folder permissions - should be fixed now:
Whay do you have your GFX power cables going from the top corner? It would look much better from one of the side grommits surely?
Re-use of old parts (Fuzion, Heatercore, DDC1) with cheaply purchased "pre-loved" XSPC reservoir and EK-470 block.
Took a 465GTX from 91C and 81% fan to 46C and silence.
Note how perfectly that heatercore fits in a Fractal Design Arc Midi!
Do I see a GTX 550Ti underneath that?haha
Otherwise awesome build, I've been considering using a front-mounted radiator in a pull config when I can, looks pretty good
Looks like youve armour plated your mobo , i could do with that, im always dropping screwdrivers and stuff in there when im messing with it.
Love how you went with smaller tubing and didn't follow the sheep and it looks great!.
Really don't like fat tubing tbh. Wish I'd gone 16/10 instead of 13/10 though. Spent a bit too much on fittings to change it now lol.
Ill stick mine in here now its finished
why does your tubing go all over the show?
shortest route = fastest flow = best temps
Agreed. A lot of people think you have to have a rad in-between each component, but not so, shortest route all round is better.
