AMD Radeon R9 290X with Hawaii GPU pictured, has 512-bit 4GB Memory
22 Aug 2008
That is boost clock isn't it? Actual proper OC would no doubt be higher, considering AMD were selling 7970s clocked at 1GHz out the box last gen. You might need to wait for a custom BIOS to raise power limit/disable boost/etc to unlock the full potential.
God I can't wait to get 2 of these under water! :D
18 Oct 2002
"The leaker claims that his sample could run at 1020 MHz core clock and 1250 MHz memory clock. That would be the peak performance for the new Radeon (we don’t know yet if this is the reference clock)."
http://videocardz.com/45753/amd-radeon-r9-290x-slightly-faster-gtx-titan
So it looks like those benchmarks we have seen might have been with the card running at its maximum overclock.Obviously don't know whether that was with any voltage increases.
I would imagine 1.3GHZ will be the ceiling with max allowed volts, under water.
Caporegime
OP
12 Jul 2007
United Kingdom
But why is it clocked so low...
The day AMD stick Elpida memory on the flagship gpu is a sad day for mankind. :(
I can't see it happening. Hopefully they' don't. ;)
That will probably be the default boost clock id expect.
TDP 250w is likely reason.
This.
2 Jan 2012
UK.
Same here. Very expensive back in the day but it's the best piece of hardware I ever bought. Considering how long I've had it, it's also the best value.
Dell's warranty is best on monitors as well. If you're buying from UK, Dell is the best option imho. My bro had a Dell 1900 x 1200 something or other that had some power problem after years of use. Dell came out, might of even been next day and gave him brand new refurb that is still going strong today.
Man of Honour
21 May 2012
Dalek flagship
I love my Dell 30" monitor, when 4K does arrive I don,t want it all packed into a 32" screen I need a bigger screen so I can play Civ5 and RTW2 type games with more on screen.
Caporegime
20 May 2007
Surrey
Sorry i had a load of different posts quoted and misunderstood, I've edited my post. :)
Just for the record as well, i was talking about memory clock as that is what everyone was on about.
I just thought perhaps they were mentioning the 1250mhz was the peak memory clock they could get seen as the ref clock is supposed to be less.
1125mhz does seem like a very low ref clock
Obviously with overvolting the core will go further than 1020mhz :p
6 Oct 2007
North West
So AMD take the single GPU performance crown back, what will be Nvidia's answer?
Will the titan and 780 drop in price when they get kicked to the kerb by the 290x? that's if it even comes in cheaper.
Caporegime
20 May 2007
Surrey
So AMD take the single GPU performance crown back, what will be Nvdia's answer?
All going to be about price. If it is $650 as rumoured (which will be £550 or thereabouts here) then I think AMD are a bit too late to the party.
If they price it under the 780 (so £450) then they will be on to a winner and Nvidia would probably have no choice but to lower prices/release a Titan ultra (and therefore re shuffle the price points of 780 and titan)
Wednesday will be interesting, even though i have no intention of ever spending ~£500 on a graphics card :p
27 Feb 2012
Let's wait and see if AMD have enough extra grunt to warrant losing 3D, hopefully we get some actual proper benchmarks on the 25th as i'll put off building my mATX rig if they make it worthwhile :D
