** THE BEST SELLING LCS IS BACK - Intel Liquid Cooling Solution - TS13X **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Arriving next week we have the newest revision of the high performance Liquid Cooler from Intel
This is by far and away our best selling LCS unit.
Intel Liquid Cooling Solution - TS13X High Performance CPU Cooler @ £79.99 inc VAT
Designed by Intel for maximum cooling potential.
Compact, pre-assembled water cooling systems have been enjoying great popularity for some time. Intel is of course not escaped and has now brought the Thermal Solution TS13X a powerful cooling solution on the market. In this case, the set is aimed at the enthusiast Intel users who still want to put the finishing touches to its CPU. The strong cooling capacity, coupled with the quiet operation can beat any modders and overclockers heart beat faster.
Targeted for Enthusiasts and Overclockers.
Specification:
- Fan Speed: 800-2200RPM [PWM]
- Fan Dimensions: 120mm x 120mm x 25mm
- Fan CFM: 73.84CFM
- Weight: 820 g (complete set)
- Fan: 120mm LED (800-2200 rev / min, 21 - 35 dB (A), PWM-controlled, 125 m³ / h)
- Connector: 4-pin PWM
- Compatibility: Intel Socket 2011, 1366, 1156, 1155, 1150
- Hose length: about 32 cm
- Manufacturer Warranty: 3 years
Only £79.99 inc VAT.
ORDER NOW
28 Aug 2013
Looks like a standard "Asetek" cooler with some kind of "Fan shroud" on that stock fan.
Performance remains to be seen, no reviews up so far. At least it looks cool.. You know, cool. Temperature cool. "ha ha".
16 Jan 2003
by my pc. :D
Looks the same as their previous offering (which I have in a box somewhere), but with a different top/logo on the pump & block assembly. Not sure what improvements they've made though.
18 Oct 2002
Hereford
Be good to see some tests on these AIO's as there's been several new ones recently!
Just hope it works better than their marketing/translators!
Caporegime
29 Jul 2011
In acme's chair.
I am of the opinion that they are all pretty hopeless. Ive had two Kuhler 620's, one was just about sufficient to keep my i7 930 at 3GHz without getting worryingly hot, and the other was just about enough to keep my 2500K at 4.2GHz in push-pull.
Even my H100 with a pair of Venom Vipers intaking cool air only keeps my 2500K at 75~ at 4.6GHz.
An air cooler that costs 20 or 30 quid less than this Intel AIO will put it to shame.
18 Oct 2002
Hereford
I'm looking at the H110 or the X60 and can't decide... A good deal is going to be the deciding factor I think as I am leaning towards the X60 for the aesthetics...
rjk
rjk
Caporegime
OP
8 Aug 2007
looks pretty good ! how does it perform against the likes of H80/100's ?
its the same as a h80 to all intents and purposes.
it is indeed. the difference is that the intel one is an intel one. :)
for this reason alone, it is by far and away the most popular. with it being an OEM solution from the CPU vendor, it has the biggest following
these were targeted as being the OEM cooler for 2011 when it was first released. so they are capable of 2011 temperatures.
rjk
rjk
Caporegime
OP
8 Aug 2007
you could always be ironic :D
Asetek AMD Mounting Kit (35-150-2000037) @ £2.99 inc VAT
Replacement AMD mounting hardware for all Circular Pump Asetek LCS CPU Coolers
Compatible with AMD Sockets
Works with the following cooling solutions:
- Alpenföhn -Wasser- All-In-One CPU Watercooling Solution
- Antec Kúhler H2O 620 Series 4 CPU Watercooler
- Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler
- Corsair Hydro H55 Quiet Liquid CPU Cooler
- Corsair Hydro H90 140mm High Performance Liquid CPU Cooler
- Corsair Hydro H110 280mm High Performance Liquid CPU Cooler
- Intel Liquid Cooling Solution - TS13X High Performance CPU Cooler
- NZXT KRAKEN X40 AIO Water Cooling Unit - 140mm
- NZXT KRAKEN X60 AIO Water Cooling Unit - 280mm
- Thermaltake Water 2.0 Pro CLW0216
- Thermaltake Water 2.0 Performer CLW0215
- Zalman CNPS20LQ CPU Liquid Cooler
- Zalman LQ310 Ultimate Liquid CPU Cooler
- Zalman LQ315 Ultimate Liquid CPU Cooler
- Zalman LQ320 Ultimate Liquid CPU Cooler
Only £2.99 inc VAT.
ORDER NOW
Caporegime
29 Jul 2011
In acme's chair.
He'll still need the £80 cooler...
Even If he sells his core system for just £60, thats £140 which is enough for a used 2500K and a board. A stock 2500K with the stock cooler will destroy almost any socket 775 setup. You would have to have a Q9650 with a fair overclock to get even close.
And if he does have a Q9650 for example, then the core system would sell for a-lot more, meaning he could probably get a 2600K and a board, at which point there is no point even comparing.
Man of Honour
13 Oct 2006
I think people underestimate the Q9x50 - though to be fair I was using some exotic RAM that allowed for stupidly high bus speeds. I upgraded my Q9550 @ 4GHz w/ GTX470 SLI to a 3770K and 9 out of 10 games were pretty much same speeds give or take*, no real difference in general desktop stuff - there was the odd thing that was a lot faster but unless I spent a large part of my day working with those apps it just wasn't worth the upgrade. Ended up selling it on.
* Couple of CPU bound games were significantly faster but weren't games I played much.
rjk
rjk
Caporegime
OP
8 Aug 2007
the arguing is pretty pointless.
775 is a dead socket.
intel do not produce 775 CPUs or Chipsets any longer
so there is no need for them to support it with their CPU cooler either.
a lot of CPU coolers that i am setting up at the moment from third party brands are omitting 775 support.
14 Feb 2011
Only £2.99 inc VAT.
ORDER NOW
Do you guys do an Intel 1155 fitting kit separate for one of these?
I've got one of the early revision 1 models currently being used on a Socket 2011 based system but, could do with some 1155 fitments so I can transfer it to another machine.
29 Aug 2010
Cornwall
The fan on this, for me, is like Schrödinger's fan. I hate it and like it at the same time.
I think it look nice, the way the frame slopes into the radiator, but I hate it because it's probably mediocre performance and they probably don't provide screws longer enough for a normal fan.
