**The NEW Tomb Raider Benchmark Thread**
Status
Not open for further replies.
10 Nov 2012
Northants
Haven't got fps cap enabled in EVGA Precision? (if that's what you're using)
Using AB, no cap
Have you got Shadow Play enabled? Disable it via Geforce Experience via the power button. With it enabled it was knocking down my average from 214 to 170.
Not even installed
Something not quite right there in my opinion. I would expect at least another 20 fps on the average for those clocks. Is the CPU usage high with this?
Not really one core will sit at maybe 60% the rest under 30.
Clocks are rock solid at @1320MHz, settings are set as the OP says.
Seems strange that the fps is double my refresh rate....
14 Feb 2011
1080p Run!
GTX 780@1385/1900
CPU - i7 [email protected]
Drivers 331.65/Win 7
5 Sep 2011
Surrey
1080P
Tri SLi 780Ti 1165/3800
4960@ 4.5Ghz
331.82 Win8.1
780Ti 1190/3930
4960@ 4.5Ghz
331.82 Win8.1
___________________
EDIT:
1080P
Tri SLi 780Ti 1165/3850
4960@ 4.9Ghz
331.82 Win8.1
We need more CPU Captain!
Man of Honour
21 May 2012
Dalek flagship
1440p result
4 Titans @994/1788
3930k @5.0
320.18 drivers
3 Titans, settings same as above
2 Titans, settings same as above
Single Titan, settings same as above
Status
