**Official Unigine Valley Leaderboard**
Caporegime
OP
17 Mar 2012
ARC-L1, Stanton System
Akula
2600k @ 5.2GHZ
GTX Titan @ 1446Mhz / 1917Mhz (1.400v / 300% / Skynet V2)
93.9 FPS
3928 Score
Nice Score :)
i7 920 @ 3.8Ghz
GTX 660 @ 1329 Core & 6008 Memory
Unfortunately i can't add that, your settings need to be "Extreme HD, 8x AA" your is High 4x AA.
Edit. I have a High score board. its right, ignore me. i'm old
Added :)
5 Sep 2011
Surrey
First run on water.
780 Ti Ref SC (Water)
1140Mhz Base (1280Mhz Boost)
3900Mhz Mem
4960X @ 4.7 (Water)
Win 8.1
311.93
29 Dec 2009
oop north
SLI Ti Classy score
I've managed this score after a couple of comp resets. As you guys say this is a cpu stresser. :(
3960X @ 5.47 (SS), RIVE mbd, SLI Ti Classys @ 1354 / 2148 using an EVbot.
18 Feb 2004
Lincolnshire
I7 4770k @ 4489.29/1.228v
vtx3d 290 flashed and unlocked to 290x
@ 1220/1500,
cv @ +200mv
power limit @ +50%
fan @ 100%,
temp @ 94oc ouch
vrm 1 @ 90oc
vrm 2 @ 80oc
Score = 3005
screen @ 120hz will test at 60 and see what difference it makes if any.
update made no difference really using 60hz vs 120hz.
29 Dec 2009
oop north
Failed!!!!
Back down to earth with with a thump!...:D
First single GPU score.......well short of "Akula" Titan. :p
3960x @ 5.47, EK water cooled Ti Classy @ 1409 / 2100
93.3 / 3905
MUST TRY HARDER!! :D
12 Dec 2005
I've just built my PC (spec in sig) and I'm just benching it to make sure it's working properly more than anything. Everything is at stock. I'm seeing scores on here of like 4000, madness.
Mine only came in at 1134! Is this about right for my rig?
15 Oct 2009
