Sniper Elite V2 Benchmark
Man of Honour
OP
21 May 2012
Dalek flagship
Thanks.
Benchmarks are dangerous, seems sandy bridge and slow pci-e are dragging me down. Thinking about a 4930k upgrade :eek: Might just have to dabble in some quadfire if I did that, have 2 more 290's for mining :p
X79 is a dangerous platform to get onto, it is so good you always want more.
Socket 2011 can seriously damage your wallet.:D
17 Jun 2005
Near Brighton
If i was to go to x79, Probably switch to a 900d. That means more watercooling gear. That's expensive :( Would need another PSU as well. quickly turns into a several thousand upgrade lol
Edit: Updated scores, not much improvement but there is still distance to go. Only at +81mv for core voltage right now.
Man of Honour
OP
21 May 2012
Dalek flagship
And on the scoreboard.:)
6 Aug 2009
Wales
1080p
Single 290X @1260/1625
4930k @4.7
Sniper Elite V2 Benchmark Report
Created: 2014-02-24 at 19:24:36
Build Version: 1.13, Apr 11 2013
Average FPS: 57.8
Minimum FPS: 30.3
Maximum FPS: 253.9
Nice score kaaps:cool:
I have a quick question guys if i may, rather than starting a new thread thought i'd try here.
I'm going to be putting my 290X underwater next week, and my question is:
The max my card can do on Air is around 1240/1500 -1250/1625(depending on benchmark), How does watercooling your GPU help with overclocking?
Does having a low load temp make a card more stable? or is it just the fact that due to lower load temps, you're able to run more voltage thus getting a previously unstable clock, stable?.
It's bugged me for a few days, my thinking is that colder temps must make it more stable, i've ran a benchmark first thing in the morning and completed it successfully, yet at the same clocks and voltage later in the day it failed.
Sorry if it's a dumb question guys, just looking for some clarification to ease my tormented mind.:D
Man of Honour
OP
21 May 2012
Dalek flagship
Watercooling improves things all round but don't expect a huge jump in performance.
It helps with stability quite a bit, cooler is better.
You can use higher volts due to temps being lower but this will only allow you to overclock a little bit more.
You should see a lot less artifacts when benching.
You will be looking at about 15 to 20mhz higher on the cores in performance.
With watercooling it is the all round package, more performance, less noise, more stability, lower temps and better looks. All these together make it well worthwhile.
Caporegime
24 Sep 2008
Essex innit!
Created: 2014-02-24 at 22:26:27
Average FPS: 58.9
Minimum FPS: 41.4
Maximum FPS: 80.8
Number Of Frames: 4511
Average Frame: 16.990ms
Minimum Frame: 12.382ms
Maximum Frame: 24.157ms
Machine Name: GREG-PC
Monitors: 2
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16328MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX TITAN
Feature Level: DX11.0
Driver version: 9.18.13.3489
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
1080P single Titan @ 1084/3734 - 3930K @ 4.625Ghz
Just a quick run to make sure and will probably do a decent run tomorrow :)
14 Feb 2011
Updated!
Created: 2014-02-24 at 22:59:28
Build Version: 1.05, Jun 7 2012
Average FPS: 106.0
Minimum FPS: 42.5
Maximum FPS: 532.1
Number Of Frames: 8118
Average Frame: 9.436ms
Minimum Frame: 1.879ms
Maximum Frame: 23.515ms
Machine Name: USER-PC
Monitors: 2
System RAM: 16326MB
CPU: Intel(R) Core(TM) i7-3960X CPU @ 3.30GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX 780
Dedicated VRAM: 2966MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
2x780's @ 1250/1700
Cpu 3960X @ 4.5ghZ
16 Nov 2013
Created: 2014-02-25 at 17:47:04
Average FPS: 56.3
Minimum FPS: 24.9
Maximum FPS: 176.6
Number Of Frames: 4306
Average Frame: 17.756ms
Minimum Frame: 5.663ms
Maximum Frame: 40.232ms
Machine Name: BRENT-PC
Monitors: 1
System RAM: 6135MB
CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
Number of Cores: 8
Dedicated VRAM: 2994MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
gtx 780 @ 1280/1852
Cpu i7960 @ 4.2 GHZ
9 Nov 2006
Earth
4770k @ 4.3 780 Ti @ 1300/1950
Created: 2014-02-25 at 16:15:01
Average FPS: 66.8
Minimum FPS: 24.5
Maximum FPS: 313.8
Number Of Frames: 5116
Average Frame: 14.965ms
Minimum Frame: 3.187ms
Maximum Frame: 40.899ms
Machine Name: KENNY-PC
Monitors: 1
System RAM: 8146MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 780 Ti
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
14 Feb 2011
Update!
780's 1293/1700
3960X @ 4.5
Created: 2014-02-25 at 12:51:22
Average FPS: 109.1
Minimum FPS: 40.1
Maximum FPS: 557.6
Number Of Frames: 8353
Average Frame: 9.169ms
Minimum Frame: 1.794ms
Maximum Frame: 24.952ms
Monitors: 2
System RAM: 16326MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Permabanned
19 Feb 2014
To
Ok I uninstalled the Standalone and reinstalled my Steam copy to play the 3 DLC's I never knew about (played Hitler one) so v1.05 to v1.11
But my Logs have mad high FPS that cannot be true for those settings in the logs which are same as all others here and in OP.
The FPS do not match screen capture so I deleted the folder and now I still can still bench but have no folder with logs.
