Sniper Elite V2 Benchmark
5 Sep 2011
Surrey
Cheers Kaapy.
Khem, just try adding your cdkey to steam and let it install that way. All the support sites just keep saying use auto update.
Not sure why I'm helping you TBH, I like being at the top :D
6 May 2012
Wigan
4770K @ 4.7 Sli 780's @ 1398/1877
Sniper Elite V2 Benchmark Report
Created: 2014-03-13 at 16:43:41
Build Version: 1.13, Apr 11 2013
Average FPS: 125.1
Minimum FPS: 41.1
Maximum FPS: 816.3
Number Of Frames: 9590
Average Frame: 7.993ms
Minimum Frame: 1.225ms
Maximum Frame: 24.337ms
Machine Name: MR-NORLEYHALL
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16322MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 780
Feature Level: DX11.0
Driver version: 9.18.13.3523
Dedicated VRAM: 2934MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: ON
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Higher GPU overclock.
CPU: AMD Phenom II x6 1090T @ 4.2Ghz
GPU: Radeon 7870XT (Tahiti LE) @ 1215 / 1615
27.7 up from 26.5, +5%
Previous GPU: 1150 / 1575.
Created: 2014-03-13 at 16:55:15
Build Version: 1.05, Jun 7 2012
Average FPS: 27.7
Minimum FPS: 13.2
Maximum FPS: 281.7
Number Of Frames: 2115
Average Frame: 36.150ms
Minimum Frame: 3.549ms
Maximum Frame: 75.846ms
Machine Name: HOME
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 8153MB
CPU: AMD Phenom(tm) II X6 1090T Processor
Number of Cores: 6
GPU Name: AMD Radeon HD 7800 Series
Driver version: 8.17.10.1267
Dedicated VRAM: 2030MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
31 May 2012
2500k 4ghz - 290p Tri-X 1230/1550
1080p
Created: 2014-02-25 at 01:55:10
Average FPS: 45.9
Minimum FPS: 22.0
Maximum FPS: 125.7
Number Of Frames: 3520
Average Frame: 21.775ms
Minimum Frame: 7.958ms
Maximum Frame: 45.423ms
Machine Name: SIEB
Monitors: 1
System RAM: 8149MB
CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Number of Cores: 4
GPU Name: AMD Radeon R9 200 Series
Dedicated VRAM: 3072MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
6 May 2012
Wigan
4770K @ 4.7 --- 780 @ 1398/1928
Created: 2014-03-20 at 12:55:01
Average FPS: 65.2
Minimum FPS: 24.6
Maximum FPS: 798.6
Number Of Frames: 4999
Average Frame: 15.338ms
Minimum Frame: 1.252ms
Maximum Frame: 40.631ms
Monitors: 1
System RAM: 16322MB
Number of Cores: 8
Dedicated VRAM: 2963MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
7 Aug 2012
4770K @4.4Ghz
7970 CF @1185/1600
Catalyst 13.12
Created: 2014-03-20 at 15:34:51
Average FPS: 79.2
Minimum FPS: 20.1
Maximum FPS: 811.7
Number Of Frames: 6070
Average Frame: 12.623ms
Minimum Frame: 1.232ms
Maximum Frame: 49.660ms
Machine Name: MAXIMUS_VI
Monitors: 1
System RAM: 8130MB
Number of Cores: 8
GPU Name: AMD Radeon HD 7900 Series
Driver version: 8.17.10.1247
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
4 x 290Xs @1230/1550
4930k @4.7
Created: 2014-03-20 at 18:28:26
Average FPS: 114.8
Minimum FPS: 13.1
Maximum FPS: 1107.9
Number Of Frames: 8741
Average Frame: 8.712ms
Minimum Frame: 0.903ms
Maximum Frame: 76.451ms
Machine Name: HAL5
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Number of Cores: 12
Resolution Width: 2560
Resolution Height: 1600
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
3 x 290Xs @1230/1550
4930k @4.7
Created: 2014-03-20 at 18:57:55
Average FPS: 87.0
Minimum FPS: 16.9
Maximum FPS: 1132.0
Number Of Frames: 6649
Average Frame: 11.488ms
Minimum Frame: 0.883ms
Maximum Frame: 58.999ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
2 x 290Xs @1230/1625
4930k @4.7
Created: 2014-03-20 at 19:05:18
Average FPS: 59.7
Minimum FPS: 19.8
Maximum FPS: 1089.3
Number Of Frames: 4565
Average Frame: 16.763ms
Minimum Frame: 0.918ms
Maximum Frame: 50.442ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
9 Nov 2006
Earth
Created: 2014-03-21 at 14:44:23
Average FPS: 76.6
Minimum FPS: 39.0
Maximum FPS: 179.1
Number Of Frames: 5866
Average Frame: 13.057ms
Minimum Frame: 5.584ms
Maximum Frame: 25.651ms
Machine Name: KENNY-PC
Monitors: 1
Operating System: Windows Vista Ultimate Edition (build 6000), 64-bit
System RAM: 8146MB
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 780 Ti
Dedicated VRAM: 2994MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
[email protected] 780Ti@1420/1965
