Hitman Bench Thread
27 Jul 2004
Yancashire
My system isn't performing as good as it should in this bench. Ran the max settings as listed, at 1920 x 1080, vsync off and get:
Min: 48
Max: 74
Av: 50
This seems waaaaay too low for 780Ti's in SLI and an i7 2600k at 4.6ghz no??? (see my sig for system details)
I noted GPU usage was only about 60% per card at the most.
Caporegime
12 Jul 2007
United Kingdom
Min: 48
Max: 74
Av: 50
What do you get with a single card?
27 Jul 2004
Yancashire
I think the hitman bench might be a bit 'odd'. Doen a few more quick tests
Single 780Ti (SLI disabled in nvidia control panel)
Min 38
Max 145
Av 47
780Ti's in SLI
Ran the benchmark 3 times in a row and got the following:
Min 48
Max 74
Av 50
Min 48
Max 163
Av 58
Min 40
Max 72
Av 58
It's all over the place it seems. One thing I noticed is when in SLI my top card never clocked above 823, whilst the bottom card was boosting to 1006.
Usage was 85% max for the top card, 55% max for the bottom.
Thoughts?
Caporegime
12 Jul 2007
United Kingdom
Min 38
Max 145
Av 47
780Ti's in SLI
Min 48
Max 74
Av 50
Min 48
Max 163
Av 58
Min 40
Max 72
Av 58
Thoughts?
I think that's likely a driver issue than a bench issue mate. Otherwise we would get the same. I suspect there's also some cpu bottlenecking going on there. 780TI SLI at 1080P will need some cpu grunt.
27 Jul 2004
Yancashire
Using 334.89 drivers if that helps?
With my cpu at 4.6 should I not be getting about the same score as Gregster's Titans, at least?
Caporegime
12 Jul 2007
United Kingdom
No idea sorry mate. Greg has a 6 core cpu though so you're at a bit of a disadvantage there. Can you clock the cpu up further? I find at 1080P you need it with more than one card.
27 Jul 2004
Yancashire
Ah, didn't realise that was a 6 core, bit out of the loop on the cpu front these days.
That probably accounts for the difference then. I'm not too bothered about overclocking my cpu further to get a higher score to be honest, I just want to make sure my system is working as it should.
My score seems low compared to you AMD fellas. Must be a driver thing?
Also, I think there are a ferw issues with this game engine. In game it runs absolutely flawless maxed out and at a constant 60 fps (I always play vsynced), BUT this is only if reflections are set to low. It's weird but at any other settings higher than this for reflections it sometimes chugs into the 40's. Very odd as I can't even tell a difference in visuals.
Caporegime
12 Jul 2007
United Kingdom
Well if you do a single card bench, it will give us an idea of the level of multi gpu scaling you're getting.
22 Jul 2012
London
1080p
2600k @4.6
R9 290 @1260/1625
13.12
67.89 fps
Having a bit of trouble with dual/triple card runs here. All I can get is 80-81fps (at stock or overclocked with 2 or 3 cards) which is the same as my two 7970's.
Other benches run fine, so I dunno what the deal is...
22 Jul 2012
London
I went from 49 to 81 at similar clocks with my 7970's, and Matt's 290's are doing alright.
Then again, Shankly's 290's are doing the same thing as mine, so...?
Greg's Titans only pulling 73 is a bit odd too.
25 Nov 2011
The KOP
Agreed something does seem strange with this Bench. Am thinking does CPU overclock play more bigger part on this? my 4.4 vs 5ghz from Matt.
