**The New Official THIEF-Incorporating Bench mark Thread**
Caporegime
12 Jul 2007
United Kingdom
4 GPUs are working but things are limited by the CPU bottleneck, remember 2 x 290p @1080p should score roughly the same as 4 x 290Xs @1600p which is the case with yours and my cards. If I run @1000/1250 stock for 1600p I get over 120fps but overclocking only gets me another 3 or 4 fps.
If I was using a 4K monitor I think I could top 100fps with a reasonable overclock on the cards.
The funny part is I can get Mantle to run quadfire but DX11 refuses to run and just freezes when loading.
Post a 2x290X stock and overclocked score for 1080P and 1600P so i can compare mine thanks.
I've also found the game sometimes locks up my whole pc running the benchmark sequence and i have to hit the restart button.
Man of Honour
21 May 2012
Dalek flagship
Here is a 1080p run I did on two 290Xs @1000/1250 stock and 4930k @4.8
If I were to overclock the cards I would only get another couple of FPS.
I will do some more runs later when I get more time.
Caporegime
12 Jul 2007
United Kingdom
That is most odd. I will have to see if overclocking gets me any sort of decent gain. At stock i get this.
I've scored slightly higher than this at stock but im having some issues at the moment with the benchmark sequence freezing so ive not got round to testing an overclock. The gain for me is huge though.
How are you taking screen caps?
25 Nov 2011
The KOP
Alt-tab to window mode and screen cap will work.
Caporegime
OP
17 Mar 2012
ARC-L1, Stanton System
Caporegime
12 Jul 2007
United Kingdom
290P stock 975/1250
Kaap i scored 134fps when i overclocked as well, however it should've been higher than that for my clocks used, 1200/1625. I clicked ok without capturing the screenshot though so will try again. :mad:
Caporegime
12 Jul 2007
United Kingdom
Anyone with a better cooler is going to score higher than me easily.
1080P Highest settings
290P crossfire @1200/1625
When i submit an entry i will include the proper screen cap, don't worry.
Caporegime
12 Jul 2007
United Kingdom
