AMD: So far ahead of its time that we are launching it at the edge of space
OP
2 Jan 2012
UK.
Would love it if AMD had something competitive, been waiting a loooong time for AMD to do something. Hopefully a Rocky Style comeback just in time for Devil's Canyon launch.
Caporegime
26 Dec 2003
Mantle final release?
I can't really see where they can go with AMD FX unless the architecture has been made massively more energy efficient, FX9590 is already ridiculously hot/power hungry/stressful to motherboards.
6 May 2011
Milton Keynes
Whilst I would love it should it be some kind of Steamroller FX which could actually offer up some competition. I have a suspicion that it will probably be some kind of slightly higher clocked version of an APU or some ultra-low-power CPU.
9 Nov 2009
Planet Earth
26 May 2009
It's an APU (I listed the website contents then looked in the java file controlling the timer).
$(this).on('finish.countdown', function(event) {
$(this).addClass('hidden');
$(this).parent().html('<h1 class="countdownfinish">AMD\'s most advanced APU ever.<br />Welcome to Earth</h1>');
9 Nov 2009
Planet Earth
The name of the APU is linked to in my last post.
It is called the FX-7600P and is the first FX branded laptop APU.
It basically is a downclocked A10 7850K running at a 35W TDP instead of a 95W TDP,with 2.7GHZ to 3.6GHZ core clockspeed instead of 3.7GHZ to 4.0GHZ and a 512 shader IGP running at 600 to 666MHZ instead of 720MHZ.
However,ther FX-7600P can also use 2133MHZ DDR3 RAM,so it should not be far off an A10 7850K in lightly thread and IGP performance. The previous highest end AMD mobile CPU,the A10 5750M,had much lower clockspeeds for the IGP relative to the desktop version,so with the faster RAM,the IGP performance should be much better overall.
Over on overclock.net there are suggestions that HBM might be used,but I think it is unlikely IMHO.
12 Feb 2011
Well we saw how little difference there was between the 384 shader and 512 shader versions, so we might find that even with the lower clock speed the RAM is still a limiting factor in performance.
