Hi there
Well first of all lets start things of with my review, I shall keep it short and brief, so the system specification was:-
Intel 5930K @ 4.25GHz (4.60GHz for SLI Test)
Asus Rampage V X99
Avexir 2400MHz @ 3000MHz C15
NVIDIA Drivers: 344.07
AMD Drivers: 14.7
Windows 7 Pro 64-Bit
The cards in this review:-
Gigabyte GeForce GTX 780Ti GHz Edition 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TGHZ-3GD) @ £569.99 inc VAT
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
8-Phase power Design, compare to reference 6-phase power design, GV-N770OC-4GD V2.0 makes the MOSFET working at a lower temperature and provides more stable voltage output. Besides, over temperature protection and load balance to each MOSFET can effectively extend the card life.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1085MHz
- Core Boost Clock: 1150MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £569.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 780 HOF 3072MB GDDR5 PCI-Express Graphics Card - Retail **ALL WHITE** @ £389.99 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
http://hexus.net/tech/reviews/graphics/60001-kfa2-geforce-gtx-780-hall-of-fame/?page=12
Only £389.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Vapor-X 4096MB GDDR5 PCI-Express Graphics Card (11226-10-40G) @ £369.95 inc VAT
The SAPPHIRE R9 290X Vapor-X OC features several of the company’s industry-leading technologies and a factory overclock to deliver best in class performance with very low noise.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 4GB of the latest GDDR5 memory running at 1410 MHz (5.64GB/s effective) and high speed engine clocks of 1080MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1030MHz >
- Memory Speed: 5300Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Only £369.95 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4UX) @ £281.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Extreme factory overclock
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1126MHz
- Core Boost Clock: 1266MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £281.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (98NQH6DHXXXX) @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £439.99 inc VAT.
ORDER NOW
Each cards clock speeds!
The Results!
As you can see from the results, the GTX 970 is the real star offering GTX 780 OC beating performance out of the box with relative ease, then add in the huge overclocking ability, we achieved 1500MHz core with stock voltage and stock fan speed. We did some later testing using higher voltage and full fan speed and we were achieving around 1600MHz core, that is getting into the realms of upto a 40% overclock on the core and we've not experienced such great overclocking ability in cards for a very long time. The card ran exceptionally cool, never seeing over 60c under-load and remaining relatively quiet and add in the fact this card consumes less than 150W typically and will happily run on a decent 450W power supply is really quite an achievement. When the 970 was overclocked to beyond 1500MHz core and 8000MHz memory it was beating 780Ti and even close to matching stock 980 performance, again such an amazing achievement for a card which cost little over £250. First time I've said this but NVIDIA and great value for money in the same sentence!
Now onto the GTX 980, this card could so easily carry a £599 price point and it would still sell, the cooler, design, quality is simply oozing out of this card, easily the best reference design cooler/card NVIDIA have designed yet. Letting the card maintain itself it will run upto around 80c under-load in absolute silence. Even if you set the fan to 100% the noise levels are still acceptable and it will struggle to go beyond 60c. Then again add in the fact this card consumes around 180W you can quite easily power it with a decent 500W PSU.
People were expecting performance on the new cards to be poor, as they just look at the paper figures which shows less cores and smaller memory inter-face, yet fact is this is a whole new architecture which is far more efficient and as such the GTX 970 easily out performs GTX 780 at everything and the GTX 980 gives a 780Ti a real good fight, but once we start to include overclocking the GTX 980 absolutely destroys the 780Ti, these things are clocking to beyond 1500MHz core with ease, I've had mine upto 1600MHz core, that is with just +87mv and the stock cooler. Give these cards +200mv and a waterblock and I think we will see some 1650-1750MHz core clocks and when 8 Pack gets one 2000MHz+ shall be demolished with ease!
Conclusion
The cards! Place close attention to ETA's and stock situation
Asus GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £469.99 inc VAT - 10 Arriving today and 10 more next week
ORDER NOW
Asus GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: TBAMHz
- Core Boost Clock: TBAMHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £499.99 inc VAT - No ETA
ORDER NOW
EVGA GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2980-KR) @ £443.99 inc VAT
The new EVGA GeForce GTX 980 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £443.99 inc VAT - Arriving in 1-2 weeks
ORDER NOW
EVGA GeForce GTX 980 SC "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2982-KR) @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1241MHz
- Core Boost Clock: 1342MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £469.99 inc VAT - 50+ in stock with more due next week!
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £439.99 inc VAT - 20 in stock with 100+ due in 1-2 weeks
ORDER NOW
GALAX GeForce GTX 980 SOC 4096MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Process: 28nm
- Core Base Clock: 1203MHz
- Core Boost Clock: 1303MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £479.99 inc VAT - Arriving October
ORDER NOW
Gigabyte GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £469.99 inc VAT - 20 in stock with 50+ arriving next week
ORDER NOW
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £439.99 inc VAT - 20 due today!
ORDER NOW
Inno3D GeForce GTX 980 "iChill Herculez X4 Air Boss" 4096MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
MSI GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £439.99 inc VAT - 10 Arriving today, more next week!
ORDER NOW
MSI GeForce GTX 980 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £469.99 inc VAT - Arriving in October
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £439.99 inc VAT - 10 Arriving today!
ORDER NOW
Zotac GeForce GTX 980 AMP Omega Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90202-10P) @ £479.99 inc VAT
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1202MHz
- Core Boost Clock: 1304MHz
- Memory Clock: 7046MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
Only £479.99 inc VAT - No ETA
ORDER NOW
Zotac GeForce GTX 980 AMP Extreme Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90203-10P) @ £499.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1291MHz
- Core Boost Clock: 1393MHz
- Memory Clock: 7200MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 209W TDP
- Warranty: 3yr
ORDER NOW
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1114MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £299.99 inc VAT - 10 in stock
ORDER NOW
EVGA GeForce GTX 970 ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-1970-KR) @ £265.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1050MHz
- Core Boost Clock: 1178MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £265.99 inc VAT - No ETA
ORDER NOW
EVGA GeForce GTX 970 SC ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-0974-KR) @ £287.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1165MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £287.99 inc VAT - Arriving 1-2 weeks
ORDER NOW
EVGA GeForce GTX 970 SSC ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2975-KR) @ £299.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £299.99 inc VAT - No ETA
ORDER NOW
EVGA GeForce GTX 970 FTW ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2978-KR) @ £319.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £319.99 inc VAT - No ETA
ORDER NOW
GALAX GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card (97NPH6DT6XTZ) @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1177MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £259.99 inc VAT - 100+ IN STOCK
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £281.99 inc VAT - 30 IN STOCK
ORDER NOW
Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
- Flex Connectivity (Upto 6 Monitors)
Specification:-
- GeForce GTX 970
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £299.99 inc VAT - 100+ IN STOCK
ORDER NOW
Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £259.99 inc VAT - Arriving Today!
ORDER NOW
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £281.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1140MHz
- Core Boost Clock: 1279MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £281.99 inc VAT - 500+ IN STOCK!!!
ORDER NOW
Palit GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1051MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x Mini-DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £259.99 inc VAT - Arriving 1-2 weeks!
ORDER NOW
Palit GeForce GTX 970 JetStream 4096MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1152MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £289.99 inc VAT - Arriving October!
ORDER NOW
Zotac GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90101-10P) @ £269.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1076MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
Only £269.99 inc VAT - NO ETA
ORDER NOW
Zotac GeForce GTX 970 AMP Omega Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90102-10P) @ £299.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1102MHz
- Core Boost Clock: 1241MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 171W TDP
- Warranty: 3yr
Only £299.99 inc VAT - NO ETA
ORDER NOW
Zotac GeForce GTX 970 AMP Extreme Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90103-10P) @ £319.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1355MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 176W TDP
- Warranty: 3yr
Only £319.99 inc VAT - NO ETA
ORDER NOW
I am thoroughly impressed with the 9xx series, far more than I was with 7xx series as they bring so much to the table. They are not only faster, they are the best cards for overclocking I have ever tested, these things clock like crazy on the cores it is untrue. Then the low power consumption, low noise, increased memory to 4GB really are the icing on the cake which make these cards the total package. Oh and lets not forget the price, the 970 cost less than a 780 and absolutely slaughters it in every aspect. Then the 980 comfortably beats the 780Ti and again it cost less yet your getting so much more in terms of a complete package and future proofing.
Yes I am impressed!
Asus Rampage V X99
AMD Drivers: 14.7
Specification:-
- GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Features:-
- Custom white PCB
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
- Galaxy GTX 780 HOF @ 1125MHz / 6000MHz
- Gigabyte GTX 780Ti GHz @ 1230MHZ / 7000MHz
- Sapphire Vapor-X 290X @ 1080MHz / 5640MHz
- Sapphire Vapor-X 290X OC @ 1250MHz / 6000MHz
- Galax GTX 970 @ 1329MHz / 7000MHz
- Galax GTX 970 OC @ 1500MHz / 8000MHz
- Galax GTX 980 @ 1266MHz / 7000MHz
- Galax GTX 980 OC @ 1467MHz / 8000MHz
- Galax GTX 980 SLI @ 1266MHz / 7000MHz
- Galax GTX 980 SLI OC with voltage @ 1541MHz / 8000MHz (+87mv)
The Results!
Conclusion
- 970 offers GTX 780 beating performance out the box and 780Ti when overclocked at MUCH LOWER PRICE POINT
- 980 offers GTX 780Ti performance and better out the box with huge overclocking ability
- 4GB vs 3GB, better for 4k gaming
- Incredibly low power consumption
- Incredibly cool running and silent operation
- DID I MENTION THESE CARDS OVERCLOCK LIKE CRAZY?
- My only negative, where is an 8GB version?
- If you own a 780Ti, not a great upgrade unless you love overclocking, but 6xx series and below owners this is the upgrade you've being waiting for!!!!!
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Process: 28nm
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 209W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 171W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 176W TDP
- Warranty: 3yr
ORDER NOW
Yes I am impressed!
