Sniper Elite V3 Benchmark
Man of Honour
OP
21 May 2012
Dalek flagship
Makes me wonder what a 290x @1330/1725 would get for score:)
Are this game worth to get AMDMatt?
About 7% more than I did.:)
How much more demanding is 4k over 5760x1080? I know its like adding a fourth 1080p screen.
It is the same as adding a forth 1080p screen but you need to check out how close you are getting to your VRAM limit as the usage on this will go up by about 20% as well.
The other thing to think about with 4K is the screen area will be smaller than what you are using now but the Pixel density will be higher.
Man of Honour
OP
21 May 2012
Dalek flagship
Mantle Scores
1080p
290X @1270/1625
4930k @4.8
Drivers 14.9
Mantle
Sniper Elite 3 Benchmark Report (Mantle)
Created: 2014-10-03 at 20:17:29
Version 1.11a Build Version: 2014.10.03.001
Average FPS: 71.3
Minimum FPS: 19.8
Maximum FPS: 93.6
Number Of Frames: 5430
Average Frame: 14.031ms
Minimum Frame: 10.685ms
Maximum Frame: 50.514ms
Machine Name: HAL5
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Number of Cores: 12
GPU Name: AMD Radeon R9 200 Series
Feature Level: Mantle
Dedicated VRAM: 4096MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
4K
290X @1270/1625
4930k @4.0
Drivers 14.9
Mantle
Created: 2014-10-03 at 20:08:38
Average FPS: 21.2
Minimum FPS: 5.5
Maximum FPS: 26.5
Number Of Frames: 1635
Average Frame: 47.258ms
Minimum Frame: 37.734ms
Maximum Frame: 181.775ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Now what am I doing posting Mantle bench results, I thought this was Humbug and Matts job.:confused::D
29 Aug 2010
Cornwall
Matt there is a problem with the Super Sampling on the results screen for Mantle so I can not use them. Can you use your contacts to get this fixed as I am sure Super Sampling is in use but not indicated.
Surely saying that you couldn't use Mantle results is why nobody's been posting them?
24 Jan 2007
2 290x at 1050/1350
14.9
1080p
2700k at 4.6ghz
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-03 at 22:00:40
Version 1.11 Build Version: 2014.09.30.004
Average FPS: 105.8
Minimum FPS: 6.8
Maximum FPS: 465.0
Number Of Frames: 8060
Average Frame: 9.454ms
Minimum Frame: 2.150ms
Maximum Frame: 146.037ms
Machine Name: GARETH-PC
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 8155MB
CPU: Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
Number of Cores: 8
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Caporegime
18 Oct 2002
Ireland
Created: 2014-10-04 at 03:46:05
Average FPS: 103.2
Minimum FPS: 15.6
Maximum FPS: 649.3
Number Of Frames: 7843
Average Frame: 9.688ms
Minimum Frame: 1.540ms
Maximum Frame: 63.974ms
Machine Name: MINE
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16351MB
CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Created: 2014-10-04 at 03:42:40
Average FPS: 40.6
Minimum FPS: 5.4
Maximum FPS: 403.6
Number Of Frames: 3103
Average Frame: 24.635ms
Minimum Frame: 2.477ms
Maximum Frame: 186.248ms
Machine Name: MINE
Monitors: 1
System RAM: 16351MB
Number of Cores: 8
Resolution Width: 5760
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Clocks at 1100 core 1400 ram. I'm guessing I should disconnect 2 of my screens for 1080p run as displaying the same image on 3 monitors has to have some kind of performance difference.
Man of Honour
OP
21 May 2012
Dalek flagship
2 x 290X
1080p
290X @1230/1625
4930k @4.8
Drivers 14.9
DX11
Created: 2014-10-04 at 04:38:17
Average FPS: 128.2
Minimum FPS: 22.7
Maximum FPS: 1056.7
Number Of Frames: 9740
Average Frame: 7.800ms
Minimum Frame: 0.946ms
Maximum Frame: 43.978ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
4K
290X @1230/1625
4930k @4.8
Drivers 14.9
DX11
Created: 2014-10-04 at 04:47:25
Average FPS: 39.8
Minimum FPS: 5.6
Maximum FPS: 1064.9
Number Of Frames: 3044
Average Frame: 25.126ms
Minimum Frame: 0.939ms
Maximum Frame: 177.634ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
25 Mar 2013
Redditch
First run everything at stock
1080p
Gpu: 980SC 1241/1753 - 344.16 drivers
CPU:4770K @3.5
Average FPS: 58.6
Minimum FPS: 17.6
Maximum FPS: 531.8
Number Of Frames: 4461
Average Frame: 17.076ms
Minimum Frame: 1.880ms
Maximum Frame: 56.793ms
Machine Name: ED-209
Monitors: 1
System RAM: 32711MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 980
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
24 Nov 2013
Sweden
OK first post and some oc rounds
4930k@4750 water
single 290x@1344/1725 water:)
dx 11 1080p
catalyst 14.9
average Fps: 72.5
min FPS: 28.3
max FPS: 191.9
Created: 2014-10-04 at 14:37:33
Average FPS: 72.5
Minimum FPS: 28.3
Maximum FPS: 191.9
Number Of Frames: 5518
Average Frame: 13.793ms
Minimum Frame: 5.210ms
Maximum Frame: 35.286ms
Machine Name: PULSE88
Monitors: 1
System RAM: 32707MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
24 Nov 2013
Sweden
And ofcourse a mantle run
4930k@4750 water
single 290x@1340/1700 water
mantle 1080p
catalyst 14.9
average Fps: 74.8
min FPS: 31.5
max FPS: 98.3
Created: 2014-10-04 at 15:37:03
Average FPS: 74.8
Minimum FPS: 31.5
Maximum FPS: 98.3
Number Of Frames: 5695
Average Frame: 13.362ms
Minimum Frame: 10.173ms
Maximum Frame: 31.749ms
Monitors: 1
System RAM: 32707MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
24 Nov 2013
Sweden
290x is still a very powerful card i think, they gonna fly and give some 980s a run for they money when they are waterchilled and cpu on phasechange;)
the 290x:s they like cold very mutch.....
