Hitman Bench Thread
Caporegime
30 Jul 2013
Hmmm, didn't make a difference.
My Min FPS at 4k was 38 right until the screen went black.
Usually the sound carries on for a bit, and you can still see the benchmark FPS counter, but I could hear the sound stop for a second and then saw the min dropped to 2fps. Then it happened again and the benchmark score threw up min 0.3 fps.
Clearly there is something awry at the end of my benchmark in 4k, as I also tested at 1080p and the problem didn't occur.
Anyway, scores below
295x2 @ stock (1018/1250) + 290x @ stock (1000/1250)
5930k @ 4.4Ghz
1080p
AND
5930k @ 4.4Ghz
2160p (UHD)
Caporegime
30 Jul 2013
I used MSI Afterburner on a 4k run though and there was no bottleneck relating to the cards. The PC just seems to freeze (and actually it was a lot longer than 1 second, more like 5!) because the OSD from Afterburner stopped updating whilst it froze up.
Doesn't happen in any other games so I know it's not an issue with my PC.
Sadly, I have to physically disable the 3rd GPU because when you have a 295x2 the CCC doesn't allow you to disable crossfire on specific GPU's.
And it's too late to faff about with now :)
