The AMD Driver Thread
25 Nov 2011
The KOP
Tried synchronize made no difference. Yeah because I like to lower the voltage right down to - 31 from stock 13+
Because msi have 3 OC profile they also have high stock voltage to cover the profiles.
I would also like to match the 290 @1030.. Am not sure what's going on.
Do you have ulps disabled by any chance?
25 Nov 2011
The KOP
Ok if I disable Crossfire or disable ULPS I can then change the voltage.. I used to always have ULPS disabled reason I remember being able to change the voltage on all GPUs.
So can anyone who has ULPS enabled tell me if you can change the voltage on all your GPUs with MSI afterburner.
Thanks
Caporegime
30 Jul 2013
Tommy, think I might have sussed Far Cry 4 and AFR mode. Do not use SMAA. I'm using MSAAx2 with AFR, farmes are super good, solid 60fps and great crossfire usage but more importantly, the horrible shadow that you get in the frame has now disappeared. Must be something to do with SMAA and AFR.
I tried it your way, custom profile with AFR enabled and MSAAx2 and it all felt very odd.
Can't put my finger on it, maybe it was micro stutter but although I was getting consistant 60fps V-synced and all my GPU's (295x2 / 290x) were pretty much under 100% load it didn't feel right.
Certain effects looked sped up.
without crossfire it runs at about 35 fps but that actually felt better.
Think i'll wait for the proper crossfire drivers.
Caporegime
OP
12 Jul 2007
United Kingdom
So with ULPS on for you matt is all your other GPU's not allow the voltage change?
synchronise wont work for me because my card not the same ID tag..
I have it off at the moment, but will try later. Pretty sure for me it only changes the voltage of gpu1 when i use sync. Maybe Pete sets them individually.
A bios flash might give you the same ID. ;)
22 Jul 2012
London
My cards are all pretty much identical in their voltage requirements and clockability, so I have synchronise checked and clock them as one.
I just checked to see if they could be adjusted independently (with sync disabled obviously :)) and they can. I dunno.
ULPS is on.
Caporegime
8 Jul 2003
In a house
AMD Catalyst 15.x
Download AMD Catalyst 15.x BETA driver. This beta driver works with Windows 7 and 8.1 64-bit It has an updated Display driver, Accerlerated Video Transcoder and CCC.
Originally this driver was released by AMD to offer support for Dell Alienware Graphics Amplifier and Windows, however it supports a wide range of Mobile and Desktop products.
Package list:
Driver Packaging Version 14.502.1002-141223a-179058C
Provider Advanced Micro Devices, Inc.
2D Driver Version 8.01.01.1443
Direct3D Version 9.14.10.01080
OpenGL Version 6.14.10.13285
Mantle Driver Version 9.1.10.0045
Mantle API Version 98304
AMD Catalyst Control Center Version 2014.1223.1723.31234
Supported cards :-
AMD Radeon(TM) R7 Graphics"
AMD130A.1 = "AMD Radeon(TM) R6 Graphics"
AMD130B.1 = "AMD Radeon(TM) R4 Graphics"
AMD130C.1 = "AMD Radeon(TM) R7 Graphics"
AMD130D.1 = "AMD Radeon(TM) R6 Graphics"
AMD130E.1 = "AMD Radeon(TM) R5 Graphics"
AMD130F.1 = "AMD Radeon(TM) R7 Graphics"
AMD1318.1 = "AMD Radeon(TM) R5 Graphics"
AMD6600.1 = "AMD Radeon HD 8600/8700M"
AMD6601.1 = "AMD Radeon (TM) HD 8500M/8700M"
AMD6604.1 = "AMD Radeon R7 M265 Series"
AMD6605.1 = "AMD Radeon R7 M260 Series"
AMD6606.1 = "AMD Radeon HD 8790M"
AMD6607.1 = "AMD Radeon R5 M240"
AMD6610.1 = "AMD Radeon R7 200 Series"
AMD6611.1 = "AMD Radeon R7 200 Series"
AMD6613.1 = "AMD Radeon R7 200 Series"
AMD6640.1 = "AMD Radeon HD 8950"
AMD6646.1 = "AMD Radeon R9 M280X"
AMD6647.1 = "AMD Radeon R9 M270X"
AMD6658.1 = "AMD Radeon R7 200 Series"
AMD665C.1 = "AMD Radeon HD 7700 Series"
AMD665D.1 = "AMD Radeon R7 200 Series"
AMD6660.1 = "AMD Radeon HD 8600M Series"
AMD6663.1 = "AMD Radeon HD 8500M Series"
AMD6664.1 = "AMD Radeon R5 M200 Series"
AMD6665.1 = "AMD Radeon R5 M230 Series"
AMD6667.1 = "AMD Radeon R5 M200 Series"
AMD666F.1 = "AMD Radeon HD 8500M"
AMD6798.1 = "AMD Radeon HD 7900 Series"
AMD679A.1 = "AMD Radeon HD 7900 Series"
AMD679B.1 = "AMD Radeon HD 7900 Series"
AMD679E.1 = "AMD Radeon HD 7800 Series"
AMD67B0.1 = "AMD Radeon R9 200 Series"
AMD67B1.1 = "AMD Radeon R9 200 Series"
AMD67B9.1 = "AMD Radeon R9 200 Series"
AMD6800.1 = "AMD Radeon HD 7970M"
AMD6801.1 = "AMD Radeon(TM) HD8970M"
AMD6810.1 = "AMD Radeon R9 200 Series"
AMD6811.1 = "AMD Radeon R9 200 Series"
AMD6818.1 = "AMD Radeon HD 7800 Series"
AMD6819.1 = "AMD Radeon HD 7800 Series"
AMD6820.1 = "AMD Radeon R9 M275X"
AMD6821.1 = "AMD Radeon R9 M270X"
AMD6822.1 = "AMD Radeon E8860"
AMD6823.1 = "AMD Radeon R9 M265X"
AMD6825.1 = "AMD Radeon HD 7800M Series"
AMD6827.1 = "AMD Radeon HD 7800M Series"
AMD682B.1 = "AMD Radeon HD 8800M Series"
AMD682D.1 = "AMD Radeon HD 7700M Series"
AMD682F.1 = "AMD Radeon HD 7700M Series"
AMD6835.1 = "AMD Radeon R7 Series / HD 9000 Series"
AMD6837.1 = "AMD Radeon HD 7700 Series"
AMD683D.1 = "AMD Radeon HD 7700 Series"
AMD683F.1 = "AMD Radeon HD 7700 Series"
AMD6840.1 = "AMD Radeon HD 7600M Series"
AMD6841.1 = "AMD Radeon HD 7500M/7600M Series"
AMD6842.1 = "AMD Radeon HD 7000M Series"
AMD6843.1 = "AMD Radeon HD 7670M"
AMD6900.1 = "AMD Radeon R7 M260"
AMD6901.1 = "AMD Radeon R5 M255"
AMD6907.1 = "AMD Radeon R5 M255"
AMD6921.1 = "AMD Radeon R9 M295X"
AMD6921.2 = "AMD Radeon R9 M295X"
AMD6921.3 = "AMD Radeon R9 M295X"
AMD6921.4 = "AMD Radeon R9 M295X"
AMD6921.5 = "AMD Radeon R9 M295X"
AMD6921.6 = "AMD Radeon R9 M295X"
AMD6939.1 = "AMD Radeon R9 200 Series"
AMD6939.2 = "AMD Radeon R9 200 Series"
http://www.guru3d.com/files_details/amd_catalyst_15_x_download.html
Caporegime
OP
12 Jul 2007
United Kingdom
Supported cards :-
This driver is not recommended for normal users, it's for people who use the Alienware Amplifier.
22 Apr 2009
Birmingham
I experience regular black screens/hangs on my crossfire 7970's when using the latest Omega Drivers, first problems i've experienced with AMD cards/drivers in a couple of years.
No problems when using the previous drivers (No crashes in well over a week) so looking forward to the nect release as I always like to keep my drivers upto date, but i can't at the moment.
14 Dec 2013
Hi Matt, I have a 295x2 and fx9590 cpu running off a Silverstone 1500 watt power supply,
do you think I could add a 290x for tri-fire off this PSU?
Sorry this is off topic for the thread but I really wanted your opinion. :)
Thanks.
Caporegime
OP
12 Jul 2007
United Kingdom
Thanks.
You certainly can, but first it would be nice to know what motherboard you have and what resolution you'll be running, along with what games you'll be playing?
