![onEBbUC.jpg onEBbUC.jpg](https://forums.overclockers.co.uk/data/attachments/154/154699-f3632869785a7bc287dad7ef04d97b75.jpg)
Final Glamour Shots
Image Gallery
Hi all,
Welcome to my first truly custom build log! This idea has long played on my mind and with the help from Justin at Parvum I can finally make the case that I needed a reality.
The build originally was centered around convection currents and having the airflow assist in heat rising out of the top of the case. After some thought I have moved onto a wind tunnel airflow design, still keeping the Launch name though!
Stay tuned because this wont be your grandmas Parvum build.
Components:
MOBO: Asus Maximus VI Hero
CPU: Intel 4670K
RAM: Corsair Dominator DDR3 2400Mhz 16Gb
GPU: Asus Strix 970
PSU: Coolermaster Real Power M850W
SSD: 2x Corsair Force GS
HDD: WD Caviar Black 640GB
Watercooling:
CPU Block: EK Ltx CSQ Nickel
GPU Block: EK CSQ DCII670 (Yeah it's the only CSQ block that fits the Strix)
Ram Blocks: EK Monarch CSQ Nickel
Radiators: 2x EK Coolstream PE 240mm
Pump: EK DCP 4.0
Res: EK x3 150
Fittings: EK HD Adapters 12/16mm
Tubing: EK HD Tubing 12/16mm
Coolant: Not sure. Clear or white.
Fans: Parvum F1.0
Other:
Lighting: Aquacomputer Farbwerk RGB Lighting!
Case:
Custom designed Parvum case! [final render]
![iDyWCQQl.jpg iDyWCQQl.jpg](https://forums.overclockers.co.uk/data/attachments/154/154700-2a0682eabcfabf70ee53ea10c11af43d.jpg)
[Build at 99% Completed]
Thanks all!
![nFypUSPh.jpg nFypUSPh.jpg](https://forums.overclockers.co.uk/data/attachments/154/154701-b29d3362b8ad5d32284e666ffceae160.jpg)
