Crossfire on 16x 4x
22 Mar 2014
Denmark
Hey all
i just tried running crossfire with a mates 290x on my Gigabyte GA-P67A-D3-B3
but it appears that one card is faster than using 2 in crossfire.
Any one have experience running crossfire on 16x 4x boards ?
Pc specs
2600K @ 4,5 Ghz
16gb 1600 Mhz ram
and 2 290x in crossfire
Psu super flower 1000w gold
Permabanned
6 Feb 2010
Barnsley
the info on that board say when you run an x16 card in slot 1, slot 4 will run at upto x1
so i would say there is no point running 2 cards, it will just use more power and do sod all for performance#
When the PCIEX1_2 or PCIEX1_3 slot is populated with an expansion card, the PCIEX4 slot will operate at up to x1 mode
27 Dec 2009
Gillingham, Kent
That board can actually run two GPUs at 16x/4x. The second PCI-Ex16 slot is only limited to x1 speed if the PCI-Ex1 slots are used, otherwise it will run at 4x speed. Not ideal, but two cards should still be faster than a single card in any Crossfire supported game.
18 Aug 2005
Shropshire
Years ago I had two 5770 cards in Crossfire on a board (Abit IP35 Pro) that did 16x on one slot and 4x on the other, it was a stutter fest due to the speed difference.
OP
22 Mar 2014
Denmark
So if i only run gfx cards and nothing else in the pci-ex it should work ?
at the moment i got an Intel network card in pci-ex1
thx for all your sugestions guys rly appreciate it.. :)
25 Nov 2011
The KOP
Do you have Tomb Raider? I could bench a a game and compare are scores.
We both have quite same systems 16GB Ram, i7 2600k close clocks and 290x+290 for and 2x 290x for you..
I guess the 4x will take about 10-15fps hit
19 May 2004
You picked the worst card to xfire on that board with since they use the PCI express bus exclusively to communicate. You are running 1/8th the ideal bandwidth.
25 Nov 2011
The KOP
This is what I got!
i7 2600k @4.4
Crossfire 290x @1030/1250 - 290@977/1250
1080p
Driver 14.12
OP
22 Mar 2014
Denmark
This is what I got!
i7 2600k @4.4
1080p
Driver 14.12
Just tried it got some weird minimums :confused:
and tried Bf4 lot of stuttering and again lower or nearly equal scores to single card 45 % gpu usage on both cards :confused:
i7 2600k @4.5
Crossfire 290x @1050/1350 - 290x@1050/1350
1080p
Driver 14.12
25 Nov 2011
The KOP
i7 2600k @4.5
1080p
Driver 14.12
You overclocking them GPUs?? you beat me on the avg FPS so 4x isn't really doing what i was expecting there..
26 Apr 2004
Milton Keynes
If you're seeing the same in other titles, I would suggest those minimums are the results of the stutters caused by the bandwidth reduction to the second card.
I have 7850 Crossfire on 16x/4x and even that isn't getting the best out of both cards, and thats WITH a crossfire bridge.
As your 290s don't even use a crossfire bridge, it can't even make up any lost bandwidth there and am guessing it's hitting some pretty hard bottlenecks :(
Do you know anyone else with a motherboard better cut out for Crossfire whom might let you test the cards in thier rig to compare?
