But by merging earlier - like all the other morons - he would be incorrect, and be contributing further to the already dire state of that traffic jam. The queue would be half that length if people merged properly.
This sort of thing annoys me more than I would like to admit.
:Edit: Ok Squerble, good point, fixed.
What you do is create a far worse traffic jam, that affects unrelated routes.
500m que in one lane, or 250m que using two lanes.
Now if there's a roundabout 300m from the narrowing, by queuing like an idiot you've jammed the roundabout up in all directions.
Doesn't have to be signposted.
Turning roundabout traffic lights off at night would do the trick too while they're at it
Alternately with merge in turn you've blocked two lanes of carriageway one of which could have been used for emergency services.
That said, I've nothing against MIT in principle, but if 90% of drivers decide to form one long queue, the other 10% are simply taking advantage of the situation, majority rules.
What, they aren't taking advantage their driving properly. People should learn and use two lanes, not force others to drive in one lane.
Great so those six junctions and side rodes you blocked, means the ambulance is 3 miles further back, because that's all hammed up.
Utterly silly comment.
Wow calm down dear. If everybody else is queuing you should respect that, just like somebody else might have a difference of opinion.
Yes it does. If there is no sign saying "Merge in Turn" then you are required to move as soon as it safe to do so, and before your lane runs out. ONLY if that sign is there will the correct option be merge in turn. And you will never see that sign on fast roads, because on a fast road merge in turn is a stupid idea. It only works on slow roads, where all lanes move at the same speed - the slower the better. Because (a concept many here struggle with) if a vehicle moving at 70 tries to merge into a lane moving at 56 then a lot of braking is required. And someone is going to time it wrong, over-brake, cause a concertina effect and cause yet more frantic braking etc. Seriously, why do so many people not understand this? I'm going to go out on a limb here and guess that all the people saying "merge in turn" are the one shooting down the right-hand lane and pulling in at the last moment, before feeling desperately smug about how only they use lanes properly. No, you aren't.
Why should I respect that. Merge in turn is quite clear. It's there for a reason.
It's you who needs to learn.
You need to learn to be more tolerant clearly. I said I agree with MIT in principle, however, what people are doing on the road at that exact moment dictates the correct course of action and response.
