The GTX 980 Ti owners thread.
29 Sep 2014
Caithness , Wick
Mine have arrived :D
13 Mar 2007
South Yorkshire
yellow pcie cable :( my poor eyes are being drawn from that lush copper to the yellow....get the wallet out and get some braided cables...for the sake of my eyes lol :p
It's getting recased and upgraded in next few weeks. I'm waiting for cablemods to get back to me to see if their kit will fit the Seasonic 1000w plat psu. No reply yet :(
13 Mar 2008
Ireland
GTA V using default fan profile - top card hit 83 degrees with bottom card hitting 74. Fans reached 60%.
Cards boosted to 1250 but regularly went back down to 1100.
Using 1-1 profile - top card hit 70 degrees with bottom card hitting 64.
Cards boosted to 1265.
This is with the front panel off and ambient temp quite low. Only played for half an hour and am off to bed now.
Hmm, that's odd. My cards boost to 1290Mhz at a minimum and stay there. Some games and benchmarks have them at 1303Mhz.
Temps max at 83 degrees as we know on default fan profile. Your temps look rather accurate for the cooler type in SLI I think. Do test it with the front panel on, see what happens then please.
Strange that yours aren't boosting as high. Have you tried the Witcher 3?
30 Mar 2010
I'm starting to wonder if it's even worth waiting for a Classified. EVGA apparently don't bin their chips, but Gigabyte does for the G1. People are posting really nice ASIC scores on overclock.net
13 Mar 2008
Ireland
The Classifieds and Kingpins are binned, since they're made for lots of OC'ing under water and LN2.
1 Jun 2004
Got my Pali Reference Ti at a stable +250 core + 500 mem. Giving 1467mhz boost! Custom fan curve to ramp up a bit more. Not going over 70 degrees. Really need to get another one.
29 Sep 2014
Caithness , Wick
I'm banging straight into the power limit @ 1440 , dips to 1400 depending on scene , power limit only goes to an extra 6% , will have to wack a new bios on :/ these @ 100% havnt broke 65 , fsr better than my 980 SOC coolers ! That would eat 91 @ stock if temp limit and time was left . They are hair dryers above 60% however :D
( fired trike extreme btw )
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and TROH updated.:)
The Roll of Honour.
Make Reference, MasterOC, Link, Date 18/06/2015
Make EVGA SC ACX, Malesu, Link, Date 17/06/2015
Make EVGA SC ACX, Mayh3M, Link, Date 17/06/2015
Make EVGA SC ACX, IT Troll, Link, Date 17/06/2015
Make EVGA SC Ref, jetpaczx, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, Brutus, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, youdsy, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, HidYn, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, Matthew89, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, delpy8, Link, Date 17/06/2015
Make EVGA SC ACX, Axekickjack, Link, Date 17/06/2015
Make EVGA SC ACX, ArnieRambo, Link, Date 16/06/2015
Make EVGA SC ACX, agnes, Link, Date 16/06/2015
Make EVGA Hydro Copper, Giggz, Link, Date 16/06/2015
Make EVGA Hybrid, Muska, Link, Date 16/06/2015
Make EVGA Hybrid, is149, Link, Date 16/06/2015
Make Reference, The Mad One, Link, Date 15/06/2015
Make EVGA SC ACX, Valenni, Link, Date 15/06/2015
Make EVGA SC ACX, OldBoy75, Link, Date 15/06/2015
Make EVGA Hybrid, shiver, Link, Date 14/06/2015
Make Reference, ICEx21, Link, Date 14/06/2015
Make Reference, varkanoid, Link, Date 13/06/2015
Make EVGA SC ACX, JunglistE, Link, Date 13/06/2015
Make Reference, Gripen90, Link, Date 12/06/2015
Make Reference, Strife212, Link, Date 11/06/2015
Make Reference, saintdefender, Link, Date 11/06/2015
Make Reference, crazy8s, Link, Date 10/06/2015
Make Reference, Tom Martow, Link, Date 10/06/2015
Make Reference, rpggamesplayer, Link, Date 10/06/2015
Make Reference, toon_mad, Link, Date 10/06/2015
Make Reference, jjgreenwood, Link, Date 10/06/2015
Make Reference, Razor Time, Link, Date 10/06/2015
Make Reference, SeeNoWeevil, Link, Date 10/06/2015
Make Reference, RyanF, Link, Date 09/06/2015
Make Reference, roozor, Link, Date 09/06/2015
Make EVGA SC ACX, perosus, Link, Date 09/06/2015
Make Reference, ZombieDescartes, Link, Date 09/06/2015
Make Reference, Techen, Link, Date 08/06/2015
Make Reference, Rap1D, Link, Date 06/06/2015
Make Reference, khemist, Link, Date 06/06/2015
Make EVGA SC Ref, ciggybumly, Link, Date 05/06/2015
Make EVGA SC Ref, N19h7m4r3, Link, Date 04/06/2015
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
25 Oct 2007
Los Angeles
70+ for air cooling. Lower is better for water and LN2
Lower is better for h20? Why is that? I would have thought the higher the better?
EDIT, found this post: http://forums.anandtech.com/showpost.php?p=33444605&postcount=16
GPU-z basically reads off info burned into the chip at time of testing, and for some GPUs like 79xx it seems to be more or less true. But NV GPUs are a different story, which is why you can get senseless numbers like 104% quality.
IF ACCURATE, and if the ASIC% means what TPU says it means, then the higher %, the lower your voltage needs to be to hit stock speeds, and the better it will undervolt. The lower the %, the higher your default voltage to hit stock speeds, but the better it will overvolt--but you will also need to water cool it to keep temperatures safe.
70-79% is about average for 79xx series and 78xx series apparently.
For other GPU series GPU-z gives you nonsensical % anyway, especially for NVIDIA GPUs which apparently use a different scale than AMD GPUs. They might fix this for future versions of GPU-z.
As someone said above, you can't compare percentages between different GPUs, only within the same GPU, due to different scales for different GPUs.
