The Fury(X) Fiji Owners Thread
5 Sep 2011
Surrey
UkSoldierboy just seen your post, AOC still having issues with AMD cards?
Email Shane Partiff @ AMD, probably the quickest way to get that sorted. AOC panels use a non standard CR timing which seems to play havoc on AMD cards in particular. There was a fix implemented in the driver for the 290x but sounds like for whatever reason it's not working on Fury X
6 Aug 2009
Wales
Thanks bud,
I'll see if AMDMatt can assist first then try emailing :) just a pain, it's like the monitor knocks off for a split second, only at 60hz, 30hz its fine.
8 Jan 2014
The gigabyte guy has a gta v vid uploaded
Quite a bit of hitching in gta v. Though to be fair he had all the advanced stuff maxed. And 8x reflection msaa for some reason with regular aa off.
Hmm, VRAM usage remains well below 4GB. Is this normal for 4K max settings - AA?
