Alien Isolation Benchmark
22 Jan 2015
4790k @4.5GHz
Titan X x2 @stock 1002/1753
353.62 Drivers
3440x1440
Average Frame Time(ms),Min Frame Time(ms),Average FPS,Max FPS,Benchmark Name
6.41,4.38,156.11,228.41,tessellation
8.73,4.27,114.52,233.97,lab_room_flyby
5.00,4.49,200.06,222.92,volumetric_light
10.25,5.31,97.58,188.47,large_shadowcaster
8.74,8.00,114.36,125.02,lab_room
7.83,4.27,136.53,233.97,Summary
Engine Settings,,,,
Graphics
Stereo Mode=Off
Depth of Field=On
Level of Detail=Ultra
Texture Filtering=Anisotropic 16x
Full Screen=FullScreen
Deep Colour (30bpp)=On
FullScreen Resolution 30bpp=3440x1440
FullScreen Resolution 24bpp=3440x1440
Windowed Resolution=1920x1200
Vertical Sync=Off
Particles=Ultra
ShadowMapResolution=2048
ShadowMapping=Ultra
MotionBlur=On
ChromaticAberrations=On
FilmGrainIntensity=1.0
Planar Reflections=On
Screen Space Ambient Occlusion=HDAO
Streaming Texture Heap Size=Default
Streaming Model Heap Size=Default
AntiAliasing=SMAA T1x
Field Of View=47
Volumetric Lighting=On
Multithreaded Shadow Rendering=Off
Audio
SFX Volume=10
Music Volume=3
Speaker Mode=Surround
Audio Language=System
22 Jan 2015
And with an OC on the cards :
4790k @4.5GHz
Titan X x2 @ 1200/1980
353.62 Drivers
3440x1440
5.65,3.84,176.95,260.48,tessellation
7.72,4.61,129.55,217.16,lab_room_flyby
4.44,3.54,225.06,282.65,volumetric_light
8.97,4.72,111.53,211.91,large_shadowcaster
7.71,7.22,129.73,138.60,lab_room
6.90,3.54,154.56,282.65,Summary
Engine Settings,,,,
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=3
22 Jan 2015
So SLI doesn't work too well in this game then ? I was getting just 54% GPU usage on both cards and when I turned off SLI that went up to 96% and the scores were only just shy of the two card scores.
19 Sep 2009
Riedquat system
Yeah the default SLI profile is very poor and scaling is non existent at certain parts of the game. At 4K this meant 40fps in places for me :mad:
I had a look online and found some info that fixes the scaling but may produce some graphical anomalies in places(?)
Change SLI compatibility bits (DX1x) to 0x0C0080F5 then also change shadowmap resolution 2048 line to <Quality name="4096" int="4096" precedence="4"> in the engine_settings.xml file.
Running the ingame benchmark using default profile and settings from this thread at 4K (970 x 3):
Average FPS - 65.07, 46.66, 95.02, 38.88, 48.81
Average Frame Time(ms) Min Frame Time(ms) Average FPS Max FPS Benchmark Name
15.37 6.64 65.07 150.67 tessellation
21.43 6.61 46.66 151.33 lab_room_flyby
10.52 8.54 95.02 117.11 volumetric_light
25.72 8.94 38.88 111.89 large_shadowcaster
20.49 19.39 48.81 51.58 lab_room
18.71 6.61 58.89 151.33 Summary
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
FullScreen Resolution 30bpp=3840x2160
FullScreen Resolution 24bpp=2560x1440
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Streaming Texture Heap Size=Ultra
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Using tweaked profile:
Average FPS - 102.34, 100.63, 119.25, 92.59, 104.84
9.77 3.04 102.34 329.38 tessellation
9.94 7.59 100.63 131.75 lab_room_flyby
8.39 6.4 119.25 156.32 volumetric_light
10.8 2.52 92.59 397.46 large_shadowcaster
9.54 7.32 104.84 136.54 lab_room
9.69 2.52 103.93 397.46 Summary
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapResolution=4096
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
I'm guessing that this is why there are very few Nvidia results posted here :p
Man of Honour
OP
21 May 2012
Dalek flagship
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Do you want me to use the default profile for the scoreboard ?
Caporegime
12 Jul 2007
United Kingdom
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Careful, Greg will look down on you for 'driver tweaks'. :p
22 Jan 2015
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Engine Settings
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Thanks a lot stooeh, I'll have go with that and see the results are. It's odd that this hasn't been set already as the game's been out a while now. Are there any similar tweaks for Star Citizen, that's another dog when it comes to SLI?
22 Jan 2015
Wow, what a difference a tweak makes.
Previous 3440x1440 average with small OC was :
154.56
Average after applying the tweak that Stooeh posted for SLI.
193.06
30 Jan 2007
PA, USA (Orig UK)
Even at stock, and with increased voltage and power limits, according to MSI Afterburner my gpu speed is throttling which seems REALLY odd to me.
EDIT: Seems I was wrong, it was vsync that seems to be limiting the clock speed rather than it throttling. Re-ran the Alien Isolation bench with vsync off and got almost double the frame rate and no apparently declocks (beyond small glitches).
22 Jan 2015
New rig so here's a new score.
5930k @4.4GHz
355.60 Drivers
3440x1440
Average: 201.59
4.97,3.55,201.19,281.85,tessellation
5.36,4.28,186.45,233.81,lab_room_flyby
4.22,3.65,236.92,274.05,volumetric_light
5.38,3.45,185.84,289.52,large_shadowcaster
5.06,4.06,197.53,246.24,lab_room
5.00,3.45,201.59,289.52,Summary
Engine Settings,,,,
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Windows 10 Pro too
Man of Honour
OP
21 May 2012
Dalek flagship
5930k @4.4GHz
355.60 Drivers
3440x1440
Average: 201.59
Engine Settings,,,,
Graphics
Stereo Mode=Off
Depth of Field=On
Vertical Sync=Off
Particles=Ultra
ShadowMapping=Ultra
MotionBlur=On
Field Of View=47
Audio
SFX Volume=10
Music Volume=10
Windows 10 Pro too
For the scoreboard this (ShadowMapResolution=4096) needs to be 2048.
10 Sep 2009
CPU: i7 860 @ 3.8GHz
GPU: 1x R9 290 @ 1053/1376
Catalyst 15.7
1920x1080
mAycITxsGekwsa2jJq6P26MQgPxOBwGKNcerRHAQlORBH8hb05WWYfVCA94pJSLtLbHHtXobR3LwxWGRmHJbG7fYcmXCQvVO0sDpKf3e3NPvtl_oUEMR741KVt3i0SE6j_0opVQlQ4b7Q4Up8JTkk_5uVyiAUhf4r3SJg5MLcdBwv_uU7WPKcewGR68txZhOdU9EYR2MGEUzYA3HQ5myYHEaJMxstpFrCxbrMI8A9_vvbfv55sAE6_L0gQvIQtWroqRYRwgUnz0VtsJmCFQRFgejVD-ahDH7UW64Ir68ualtiMUctWzClDipHhKwl3ffzNXTSdCFqakaUi2bBHaAS-YyJV7p414XUWpr_iiza7i4vAOLyHUW13jOjooj5fxPAD324VVIXZHFFp46Nh1JNQZ9cEdktWKY92Pv0HP7a4McbFgPReuCWhJoqrM53rE5Y9OXi9ALuJzC4s7qkhdRqhVin7fWv8FlQAxcMgSQZ0FJDuDw-jEwH0MlhN0SAePE0CZdt4wu9a_wzocK-oOz1SY=w447-h839-no
