** SAPPHIRE 390 8GB and 380 4GB /with BACKPLATE NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We already have the new Sapphire 390 and 380 with Backplate on the way and even better we've lowered the prices further. :)
Sapphire Radeon R9 Nitro 390 8192MB GDDR5 PCI-Express Graphics Card with Backplate (11244-01-20G) @ £269.99 inc VAT
The 390 series from AMD offer great future proofing for upcoming game titles such as Star Wars Battlefront, DOOM, Half Life 3 and Fall Out 4. Featuring DirectX 12 support and 8GB of memory makes the 390 series great for current and future games at resolutions upto 4k.
The SAPPHIRE R9 390 Nitro 8GB features the latest GCN (graphics core next) architecture from AMD with 2560 stream processing units and an enhanced engine clock of up to 1040Mhz. It is equipped with 8GB of the latest high performance GDDR5 memory on a 512-bit interface and now clocked at 1500 MHz (6GHz effective) delivering higher bandwidth than earlier models. Built on a SAPPHIRE original pcb, the layout incorporates a 6-phase VDDC power design. Two 8-pin power connectors ensure adequate system power is available (up to 375 Watts total including PCI-Express power).
Specification:-
- GPU: Grenada Pro
- Stream Processors: 2560
- Core Speed: 1040MHz
- Memory Speed: 6000Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Only £269.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 Nitro 380 4096MB GDDR5 PCI-Express Graphics Card with Backplate (11242-13-20G) @ £169.99 inc VAT
The new AMD R9 380 is the ultimate do it all card, great for media streaming, gaming and featuring AMD's new True HD Audio sound for exceptional sound quality and realism. This new 380 version consumes less power than R9 280 and is also quicker at the same time. As a result this is one very cool running card which also operates in near silence and will take the fight for AMD to the NVIDIA GTX 960.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1010MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Frame Buffer / Memory: 4GB GDDR5
- Memory Width / Speed: 256 bit / 5800MHz
- Power Connectors: 2x 6-pin
- Display Outputs: 2x DVI + 1x HDMI + 1x DisplayPort
- Power: 190W TDP
- DirectX 12 Ready
- AMD True Audio
- 2yr Warranty
Only £169.99 inc VAT.
ORDER NOW
Two very nice cards, now which include backplate and higher clock speeds, whilst costing less than the previous inferior models. :)
19 Dec 2013
Newbury, UK
Apparently benchmarks show the 390 and 390x being competitive vs the 970 and 980 respectively, and with double the VRAM they are being touted in the forums as better buys than their NVIDIA equivalents (especially the 390).
5 Nov 2014
my 390 should be arriving in the next 38 mins if it hasn't already as i'm not home (someones in though), is the 390 the same gpu as the ones above?
first gpu upgrade in 5 years!
14 May 2003
Worcestershire
Mine arrived a while ago. What a huge and lovely bit of kit, hadn't quite appreciated that the backplate model is factory overclocked. Superb deal. Going to be my first view of the Crimson drivers too later... :D
18 Apr 2011
Uckfield
Mine arrived earlier aswell, looks great in the flesh and the backplate gives the card that finished look.
Cant wait to test it later tonight while munching on some Haribo's!!
