remind me of the Fractal Define S I own. Very similar in design internally.
Just to clarify, here's a full statement from Phanteks on this point: -
Whilst I appreciate the disappointment that a 240mm radiator will not fit, I just want people to know that Phanteks would never knowingly 'gimp' a case, it's not in their ethos or interests. Maybe Phanteks will offer a product around the £65 mark that has better watercooling support but maintains the Eclipse looks further down the line.
Users who are looking for more water-cooling flexibility we offer other alternatives such as the Enthoo Pro M from the Enthoo Series, which is available for a price that’s not a lot more expensive than the Eclipse P400.
TTL - maybe they didn't want to pay for the cost of retooling? They maybe using a tooling set that is already available to them, and that's just their public explanation? As many people wont understand the work and efforts needed to create a new tooling set.
What they have said isnt correct though. 10mm is more than enough to clear the mosfet coolers on the Formula (and they are pretty huge) Case width adjustment isnt needed.
Comment about pressing tolerances is also incorrect. I used to manage a factory that bent, pressed sheet steel that ended up on the london underground so annoyingly I have a lot of experience with this kind of engineering, on the offchance that is not enough though Ive shown the case to the metalshop manager (at the huge cost of loads of doughnuts for the boys) and making the press wider would not have effected the ability to have the bend in the outside of the case at all. (assuming these are the engineering tolerances they speak of)
Long and short of it is there is enough room in the roof of the case to have expanded that grill enough to have accepted an AIO fitted without making any other changes to the case.
That in itself speaks volumes though.
The Enthoo Pro M is £7 more than the entry level Eclipse and is in the same price range as the Eclipse series. There really isn't a hidden agenda from Phanteks here, it's a shame that's the general feeling though. As for your other points, I'm hardly an expert on that front, but I'll pass on your feedback to Phanteks.
Excellent pricing and it look's like they have actually thought about cable management too. If Phanteks can turn out quality case with decent features at this price point why do other manufacturers either want more money or cut back on features?
That's a great looking case at an excellent price point, me likey!
A lot of users like me may only be interested in having a single AIO cooler for the CPU and front mounting keeps it out of the way.
Loving the white one .
