** Stock Cooler Removal Information **
4 Jun 2015
Watford, Herts
Msi is also listed, but my msi 980ti has a void sticker on one of the screws, so which I it?
I emailed Msi about cooler removal and they said it is fine.
MSI UK Components Service Department <[email protected]>
13 Jul (5 days ago)
to me
Dear James,
You can remove the stock cooler without a problem.
Warranty will not be voided as long as there is no physical damage to the board.
Should the board ever need to be return for service, the original stock cooler has to be mounted on the board again.
Met vriendelijke groet,
Description: MSI™
Mainboard and VGA Customer Service
13 Jun 2011
So why is customer service saying otherwise?
This is what really ****** me off because i asked then twice two different people and was told that it voids warrenty. No doubt to get the extra money.
at the time i wanted i save some money and fit the blocks myself but didnt wanna loose the warrenty so bought the techlabs cards instead
22 Jul 2015
Aberdeen
I contacted Palit and there response was no warranty if I touch the stock cooler. Called up Zotac and they had a similar stand. It seems that in many cases it is pretty much down to individual you are dealing with. Also it depends a lot on the selling vendors in the middle. OcUK seem to have a relaxed approach but speaking to another UK based vendor; they didn't want me to remove stock cooler on any of the cards they sell or else they won't help with the warranty. Now I know where to buy. :D
19 Oct 2002
no i dont.
stock cooler removal is fine on ocuk branded cards as long as you put it back properly.
Rich arent ocuk just pcpartner so could be zotac, manli, inno3d ?
Thinking of ordering a nzxt gpu cooler bundle for my zotac amp but they are publicly saying warranty void but you are saying ocuk cards no problem, ocuk cards are zotac and so you see my predicament......
24 Jul 2008
Recently had a sapphire 290x die on me which I removed the stock cooler and added a closed loop cooler.
Managed to arrange an RMA today few days before warranty expires, ive dug old cooler out attic and proceeded to fit it tonight ive noticed im actually missing a screw and rounded another in the past should I be worried?
9 Mar 2016
I can confirm that Gainward does not allow it. Infact if the sticker is damaged at all they won't even look at the card. Here is the official response I got when I complained about it on their Facebook page:
So yeah, don't buy Gainward they really don't care about their customers!
19 Apr 2016
How about Zotac? Both are from Hong Kong.
6 Jun 2006
Leeds
I enquired Zotac support about a repair on a 680 after a mishap when removing the cooler. The answer was that I had voided warranty and they would not even consider it. I wasnt even wanting the repair done under warranty but no go was the answer from Zotac support. May not be the case now but that was the answer I got back then.
28 Aug 2014
I bought EVGA because everyone says they are good with cooler removal and stuff. When enquiring about this in customer service section on here I was told EVGA are really serious about cooler removal... So the premium I paid was wasted?
It doesn't matter what the manufacturer has said they can say something different when it is your product. So I am lead to beleive.
