Solid State Drives (SSD's) explained
13 Jul 2005
Devon
Im actually going to now get a ssd for the primary, but im not sure what im going to get for the secondary either a mechanical or ssd this would be for storing music etc and video converting,editing.
6 Jul 2007
Sussex, UK
Is there a practical use for a secondary SSD? I've just bought a bigger SSD so wondering what to do with the one to be replaced? I assume there's no advantage to installing Steam games on to it, or other software if it can all fit on the primary? I've got a 4TB HDD for all my media also.
30 Dec 2013
GPS signal not found. (11)
Unless you are likely to be frequently doing very read or write intensive tasks in parallel then there isn't really any benefit except for more space.
25 Feb 2009
I seem to be going round in circles and confusing myself.
Simply, my HDD in my 6 yr old Dell XPS has failed, I would like to fit SSD for a bit of performance. Do i just plug it in like a normal HDD and reinstall Windows?
27 Feb 2014
yes, check sata mode in bios is set to ahci before installing
25 Feb 2009
My drive came yesterday, 500GB Samsung EVO, i didn't have time to install but i did have a look in my BIOS. I cant seem to find AHCI option.
Ive got a Dell XPS 430.
If i don't have this option, am i right in thinking that it will run anyway but just not at the 6gbs SATA III speed?
13 Feb 2013
I remember when I first bought my SSD, 6+ years ago. Baby sat it for a long time afterwards, reducing writes, etc. Turns out there was no need and now I simply forget about it. Still going strong.
28 Aug 2018
I changed my HDD to SSD a long time ago. I have it on my computer and PS4 console. Thanks to it, the PC and PS start working quieter. I recommend it!
