- 1 Oct 2006
Ugh. I stand corrected, DHL just billed me £46. Damnit.
Who prints platinum? You would need a sintering laser printer.
I'm thinking of going to the Bristol one, as I want access to a laser printer. To cut balsa wood.
Anyone know what tolerance I need to build in, to slot said balsa wood together.
Nice, not a bad video at all James. I'd recommend getting a tripod for your camera and a good flat area to present on, would give you two hands to work with too.
Other than that you've got a good clear presenting voice, good quality camera and nice intros/outros.
Ok guys, a little problem with my 3D printer this morning.
I only have ea cheapo Cubify cube 2nd gen thing, so nothing much I can do to it...
but, the axis that has the extruder on, seems borked, It constantly tries to travel to the left. (as in past the stop point)
I don't know how to tell it that it is "home" or how the head knows it is in position. It was fine this morning, moved it to a new location in the house and it is now fubar.
Any ideas? So far, I have tried to move it all the way to one edge and kick it in and it didnt work =(
it does indeed have a limit switch, it is actually switching, but doing nothing. I am guessing either the other end is fubar or the switch is dead. I am trying to trace the cable, but it seems some of the casing is stuck need to get my tool box on it
