upgrade help/ advice
8 Apr 2012
North wales
hi all i have managed to pick up a second hand tower up for £30 to free up more money for my own tower i want to build
medion mt 14
pentium 3.00ghz processor ( can this be upgraded?)
2 x 2gb teamgroup ddr3 ram
1tb hdd
1gb geforce 210 graphics card
windows 10 pro 64bit
processor fan a bit noisy so looking to replace that any suggestions and also wondering if be worth upgrading my ram would i notice any difference going from 4gb to 8gb,
pc is only used for internet browsing , catch up tv , and for my lad to do his homework on
thanks in advance
APM
APM
9 Nov 2011
Wales
Have a look for used 775 CPU's,find the best and cheapest one and swop it out with what's in there now.
May as well go to 4GB RAM as well and try a small SSD to house your OS.
Download and run speccy and you'll know exactly what you are dealing with regarding your CPU and RAM.
APM
APM
9 Nov 2011
Wales
Just keep an eye on the wattages and expected running temps of the CPU's you're looking at against what is in the system now or you may want a better cooler too,or if power usage is important to you for this machine.
14 May 2003
Birmingham, England
could possibly get a quad core extreme or even a 771 xeon, usually cheaper, you'll need to get a mod tho to convert the 775 to a 771. easy enough to do. plenty of instructions on the web. works easy enough did it on a qnap 509.
however, you need to check your bios will recognise the xeon. its not too difficult to add the xeon cpuid to a bios, usually.
OP
8 Apr 2012
North wales
first of all sorry for big post im about to copy and paste everything from cpuz
CPU Name
Pentium(R) Dual-Core CPU E5700 @ 3.00GHz
Threading
1 CPU - 2 Core - 2 Thread
Frequency
2999.84 MHz (15 * 199.99 MHz)
Multiplier
Current: 15 / Min: 6 / Max: 15
Architecture
Wolfdale / R0 Step (45 nm)
Cpuid / Ext.
6.7.A / 6.17
IA Extensions
MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
Caches
L1D : 32 KB / L2 : 2048 KB
Caches Assoc.
L1D : 8-way / L2 : 8-way
Microcode
Rev. 0x00000A0C
TDP / Vcore
65 Watts / 1.288 Volts
Type
Retail (Original Frequency : 3000 MHz)
Motherboard
Model
MEDIONPC MS-7633
Socket
Socket 775 LGA
North Bridge
Intel G41 rev A3
South Bridge
Intel 82801GB (ICH7/R) rev A1
BIOS
American Megatrends Inc. A7633MLN.20B (06/10/2010)
Memory (RAM)
Total Size
4096 MB
Type
Dual Channel (128 bit) DDR3-SDRAM
Frequency
400 MHz - Ratio 1:2
Timings
6-6-6-15-1 (tCAS-tRC-tRP-tRAS-tCR)
Slot #1 Module
Team Group Inc. 2048 MB (DDR3-1337) - P/N: Team--Elite-1333
Slot #2 Module
Graphic Card (GPU)
GPU #1 Type
NVIDIA GeForce 210 (GT218)
GPU #1 Brand
GIGABYTE Technology
VRAM #1 Type
1024 MB
DirectX
12.0
Storage (HDD/SSD)
Model #1
Hitachi HDE721010SLA330
Capacity #1
1000 GB
Display
Screen #1
Samsung SAMSUNG (SAM03D4)
Screen #1 Spec
7.2 inches (18.3 cm) / 1360 x 768 pixels @ 23-60 Hz
Miscellaneous
Windows Version
Microsoft Windows 10 (10.0) Professional 64-bit
Windows Subver.
Build 10586
CPU-Z Version
1.76.0 (64 bit)
OP
8 Apr 2012
North wales
so ive done a bit of research and from what i understand the bios release date was 2010 so any processor made before then should work. So what would be best as notice current cpu is fsb 800 and my ram is 1333 does that mean i should be looking for processors with 1333mhz fsb like 8400 core 2 duo or the quad cores
if that is the case the e8400 seems like best dual core i can find and very cheap at just £6
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
Look's like MSI is the oem for the board and G41 is the chipset so theoretically it should take any of the 45nm dual and quad cores (last releases) for 775. So that's the E5***, E6*** Pentium Dual cores, E7***, E8*** Core2Duo's and Q9*** Core2Quad cpu's. That's provided that there are no limitations in the bios.
