Yellow Submarine Build
11 Apr 2013
Nr Salisbury
i will be adding the Gtx 1080 in the loop once arrived and purchased,
Temps are not to bad i got a 4.5ghz overclock stable 24 hour tested
30 mins of prime95 small ffts for a quick temp test
This is with the cpu de-lidded
Noise levels are virtually silent, its on the desk so dust is not an issue for the moment, (I will be bringing out my small leaf blower to rid of any dust in the future)
nice one, looks great, will look even better with the 1080 in the loop as well :)
21 Jan 2003
Northamptonshire
Hey fella,
I would check your GPU with GPUz to ensure its running x16 3.0 and not x8 3.0
My pcie riser is faulty and there are a lot of complaints on the TT forums for the very same issue. Only got mine yesterday.
The cheap pcie risers I bought just in case this issue occurred dont match up with the mounting bars either.
Waiting to hear back from TT at the moment.
