Intel’s Broadwell-E Flagship Core i7-6950X Processor Confirmed – 10 Core Madness For X99 Enthusiast
11 May 2014
Edinburgh
So...will these new CPU's work on the original X99 motherboards?
Say if you had a 5820k, could you get the new top of the range chip to replace without upgrading the mobo?
28 May 2007
How so? Are you referring to the Xeon comparisons?
Cheers :)
Silly priced for a desktop. Becomes quickly unmanageable from a cooling point and can't overclock for toffee.
On the workstation side it's cheaper than a lot of Xeons options but it's not really a stand out CPU in the Xeon world. For a very similar price you can have a 28 thread 3.6Ghz chip with the options of adding a second CPU.
It's an oddball chip that offers very little/nothing in either world.
28 May 2007
I think you might need a X99 board with really high end power delivery. I think once you start increasing frequency you could easily be looking at 3-400 watts.
8 Dec 2005
So £2K for a 6950X+X99+DDR4 excluding a decent GPU.
Or £1k for 5960X+X99+DDR4!
I think I would buy a 5960 system its not like anything really needs 16 threads let alone 20! I knew Intel would find a way to sting the consumer though as it re-uses the same 2011V3 socket they cannot sell yet another motherboard variant so they price gouged the CPU :eek:
27 Jan 2009
Not quite 2k for the 6950x setup unless you go to town with the Mb and ram, cpu's on pre order for just under £1400...
https://www.overclockers.co.uk/inte...rocessor-retail-bx80671i76950x-cp-617-in.html
You would not get a 5960x setup for 1k at retail prices either!
(the 6950x is still very expensive compared to haswell-e cpu's)
8 Dec 2005
It is as a decent X99 motherboard is around £350-400 + DDR4 + 6950X=£2K.
5960X can easily be had for around £780 + DDR4 + X99 cheaper motherboard=£1K
13 Apr 2006
If they are going Broadwell-E for the 6950X does that mean we will get a Skylake equivalent in the future?
Also noted that it only supports up to DD4-2400! lol
31 May 2016
Long time lurker, first post :)
I am in the process of building a new system, and had the 5960x in mind but thought I would wait to see B-E prices/performance. I am now undecided between the 5960x and the 6900k, I must admit I am new to all of this as this will be my first build, and after looking at many reviews and benchmarks they seem neck-and-neck with very little difference in results.
Should I go for the 5960x or get the new 6900k?
At the moment it seems the 5960x would overclock better (?) so maybe go with that?
New? It is £850+ new on most places, where did you see it at £780?
13 Mar 2008
Ireland
Depends on the Mobo. I noticed the Asus X99 Deluxe has a new Bios update that says support for the latest i7-X Processors.
27 Jan 2009
So your comparing apples to oranges! Cheap 5960x setup vs expensive 6950x setup! Compare like to like mb's and memory and it doesn't cost £1000 extra for the deca core..... It's a big jump but not quite that bad.... Hyperbole does not make a good (serious) argument...
