Looks at prices!
It's underkill in most situations if anything.
How so? Are you referring to the Xeon comparisons?
Cheers
So...will these new CPU's work on the original X99 motherboards?
Say if you had a 5820k, could you get the new top of the range chip to replace without upgrading the mobo?
Correct however you WILL need to update your bios before removing the 5820k
I think the only question here is, if someone was in the market for a 5820k are they better off going and buying a 6800K instead.
Considering the 6800k looking to be around £60 more on launch for next to no improvement it's a hard sell over the 5820k
Yeah, I was going to get a 6800K today but got a 5820K instead after looking at the gaming benchmarks which showed practically no difference. Couldn't justify spending the extra money for that.
So £2K for a 6950X+X99+DDR4 excluding a decent GPU.
Or £1k for 5960X+X99+DDR4!
I think I would buy a 5960 system its not like anything really needs 16 threads let alone 20! I knew Intel would find a way to sting the consumer though as it re-uses the same 2011V3 socket they cannot sell yet another motherboard variant so they price gouged the CPU
It is as a decent X99 motherboard is around £350-400 + DDR4 + 6950X=£2K.Not quite 2k for the 6950x setup unless you go to town with the Mb and ram, cpu's on pre order for just under £1400...
https://www.overclockers.co.uk/inte...rocessor-retail-bx80671i76950x-cp-617-in.html
You would not get a 5960x setup for 1k at retail prices either!
(the 6950x is still very expensive compared to haswell-e cpu's)
5960X can easily be had for around £780 + DDR4 + X99 cheaper motherboard=£1K
