Hi all. Have been reading through water-cooling guides for weeks but need guidance from you guys before i pull the trigger.
I will be cooling a 6700k (stock but may look into overclocking soon) and a gtx 1080 FE (overclocked). Could you guys look into the list below and let me know if all's complete? Do I need fittings and tubes for the graphic card block as well?
Already have a zotac 1080 FE.
My basket at Overclockers UK:
- 1 x OcUK Tech Labs - V12 Watercooling Kit 360 = £267.85
- Tubing Colourrimochill Primoflex Advanced Tubing 16/11 - Clear
- Coolant Choice:Mayhems Ultra Pure H2O Watercooling Fluid 1L
- Radiator:Coolgate G2 Radiator 10 FPI - 360mm
- Pump & Reservoir Option:XSPC D5 Photon 170 Reservoir/Pump Combo
- CPU Block:EK Water Blocks EK-Supremacy EVO
- 1 x EK Water Blocks EK-FC1080 GTX - Acetal+Nickel= £89.99
- 1 x EK Water Blocks EK-FC 1080 GTX Backplate - Black= £22.99
- 1 x Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Black= £154.99
