Narrow width RAM - ddr4
26 Aug 2009
The CPU water block connectors come out in line with the edge of the RAM slot
Just got some GSkill Trident Z - doesn't fit.
Here's a photo with the corsair vengeance LPX which is a super tight fit in the other slot.
If I want 32gb total, what are my best options? inc. performance wise
asus maximus VIII impact
just contemplating putting the cpu block on upside down.... the cooler master writing will suck..
10 Aug 2015
Usually have problems with large air coolers - this is the first time I've seen issues with water coolers - worth bearing in mind where the water block connectors protrude - thanks for the posts - useful
17 Aug 2009
The blocks on the cpu containing the pump are much larger than they were and the fashion of having the tubes exit from the side doesn't help.
I still have a working H50 and its footprint is vastly smaller on top of the tubes coming out of the top instead of the side.
