**SILENT WINGS 3 HAVE FINALLY ARRIVED**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Be Quiet have finally released the Silent wings 3 after announcing that they were looking at improving the Silent Wings 2 which was a very successful fan. The Silent Wings 3 has had a couple of design tweaks and comes in 4 different types including Non PWM, PWM and High Speed of both models. They are also available in the 120mm and 140mm.
The variety offers you different types of cooling with the non PWM and PWM for cases and CPU coolers and the High speed have the added option of adding them to your water cooling loop to improve those temps with some of the quietest fans on the market.
be quiet! Silent Wings 3 120mm PWM Fan @ £18.95 inc VAT https://www.overclockers.co.uk/be-quiet-Silent-Wings-3-120mm-PWM-Fan-FG-036-BQ.html
be quiet! SilentWings® 3 120mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
No Compromise Silence and Performance
be quiet! SilentWings® 3 120mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling. It meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
Features:
- Virtually inaudible operation at max. 16.4dB(A)
- 6-pole fan motor with three phases giving very low power consumption and less vibration
- Advanced fluid-dynamic bearing enables super-long life span up to 300,000h
- Rubberized fan frame with funnel-shaped air inlets for extremely high air pressure
- Seven fan blades with optimized surface structures ensure excellent airflow
- Removable anti-vibration mountings reduce transmission of vibrations
- PWM controlled fan speed by the motherboard
- German product conception, design and quality control
- Three years manufacturer’s warranty
SilentWings® 3 PWM fans are your best choice for any application that requires the ultimate in quiet operation and uncompromised performance.
Specification:
- Dimensions (L x W x D), (mm): 120 x 120 x 25
- Fan speed @ 12V 100% (rpm): 1,450
- Airflow @ 12V (cfm, m3/h): 50.5 / 80.47
- Air pressure @ 12V (mm H2O): 1.79
- Noise level @ 12V 100% (dB(A)): 16.4
Only £18.95 inc VAT.
ORDER NOW
be quiet! Silent Wings 3 120mm PWM High Speed Fan @ £18.95 inc VAT https://www.overclockers.co.uk/be-quiet-Silent-Wings-3-120mm-PWM-High-Speed-Fan-FG-037-BQ.html
be quiet! SilentWings® 3 120mm PWM high-speed stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
be quiet! SilentWings® 3 120mm PWM high-speed stands for state of the art technology and virtually inaudible operation. The extremely high air pressure produced makes it a perfect choice for powerful water- and air-cooled systems.
Features:
- Great performance-to-noise ratio with 28.6dB(A) at 2,200rpm
SilentWings® 3 PWM high-speed fans are your best choice for any application that requires the ultimate in quiet operation and uncompromised performance.
Specification:
- Fan speed @ 12V 100% (rpm): 2,200
- Airflow @ 12V (cfm, m3/h): 73.33 / 124.58
- Air pressure @ 12V (mm H2O): 3.37
- Noise level @ 12V 100% (dB(A)): 28.6
ORDER NOW
be quiet! Silent Wings 3 140mm PWM Fan @ £19.99 inc VAT https://www.overclockers.co.uk/be-quiet-Silent-Wings-3-140mm-PWM-Fan-FG-038-BQ.html
be quiet! SilentWings® 3 140mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
be quiet! SilentWings® 3 140mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling. It meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
Features:
- Virtually inaudible operation at max. 15.5dB(A)
Specification:
- Dimensions (L x W x D), (mm): 140 x 140 x 25
- Fan speed @ 12V 100% (rpm): 1,000
- Airflow @ 12V (cfm, m3/h): 59.5 / 101.09
- Air pressure @ 12V (mm H2O): 1.08
- Noise level @ 12V 100% (dB(A)): 15.5
Only £19.99 inc VAT.
ORDER NOW
be quiet! Silent Wings 3 140mm PWM High Speed Fan @ £19.99 inc VAT https://www.overclockers.co.uk/be-quiet-Silent-Wings-3-140mm-PWM-High-Speed-Fan-FG-039-BQ.html
be quiet! SilentWings® 3 140mm PWM high-speed stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
be quiet! SilentWings® 3 140mm PWM high-speed stands for state of the art technology and virtually inaudible operation. The extremely high air pressure produced makes it a perfect choice for powerful water- and air-cooled systems.
Features:
- Great performance-to-noise ratio with 28.1dB(A) at 1,600rpm
Specification:
- Fan speed @ 12V 100% (rpm): 1,600
- Airflow @ 12V (cfm, m3/h): 77.57 / 131.79
- Air pressure @ 12V (mm H2O): 2.16
- Noise level @ 12V 100% (dB(A)): 28.1
ORDER NOW
Reviews will be available with in the next couple of weeks.
All BeQuiet Fans Available Here
Other Fans Available Here
19 Dec 2013
Newbury, UK
The mounting system on these look really good. Going by the product description and design, are these designed more for case airflow than radiator cooling?
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
The High Speed ones are designed more for Radiators but can still be used for case fans. The normal PWM and non PWM are you case fans really.
12 Jan 2014
I am ready to post the review of the first fan- the 120mm non high speed- but waiting on be quiet! to get back to me about this:
Excuse the typo, it is Silent Wings 3 and not 2. Massive drop in RPM going from 100% PWM to 99% PWM to 95% PWM. Doesn't match their RPM to PWM curve in their website either. Both fans did the exact same here. Overall performance is nice, better than Silent Wings 2 in terms of airflow through radiator at similar/lower noise levels. It won't break any performance records, but noise prioritizing customers will love these.
3 Sep 2016
Hey guys, first post here. Currently in the market for the SW3, and have found two reviews on YT of the SW3, one of them is favorable:
But the other one compares the noise of the SW3 to the SW2 and finds that the SW3 actually emits a high pitch noise which is absent from the SW2. Comparing the two the SW3 seems to be worse in terms of noise than the previous SW2:
Have you encountered this noise, vsg28? According to the comments Be Quiet! are aware of this and are "looking into it" whatever that means.
12 Jan 2014
Not really, I used voltage control and PWM control on the fans accordingly and the tested ones were perfect. Still others left to test though, so I will check hard for this.
12 Jan 2014
Sorry to double post, but warning to those who want to use these PWM fans with the Aquacomputer Aquaero 6- looks like there's a bug on the controller that is causing the massive RPM drops I saw. be quiet! is working with Aquacomputer to see what the issue is.
2 Apr 2014
Hook
Im currently in the market for a pair of 120mm fans to replace the 200mm fan in the front of my Phanteks Enthoo Pro.
Would be cool though if BQ did these in white to go with my case :D
