Well I've boxed mine up
I did a bit more research today and decided to update both the bios and the Embedded controller software. Apparently the latter is responsible for fan usage and control. This definitely improved matters with the fans on my model but only fractionally. Furmark would still bomb after a few seconds when the gpu reached 80 degrees. It was as if the fans received their intrsuction to spin faster too late. It's a weird one. But you could hear them whirring to life right as the software fell over. So whatever the reason behind it my laptop has a fault. It is such a shame though, as I loved the laptop in every way. I haven't a clue what to replace it with
Can you point me towards that thread please? I haven't been able to find out an awful lot about this laptop. When he says 'works perfect now' i wonder what aspect he is referring to? I know you said cpu but is that causing them to crash I wonder? Football Manager is pretty demanding in the cpu department. Part of me, being the techy thinks I should hold on to this for a bit longer, but a larger part says this should be working out of the box. I shouldn't have to spend nearly £3k being a guinea pig!
But I am genuinely glad your laptop is happy! I am sure it is a beast.
