Warhammer Total War Bench Thread
Man of Honour
OP
21 May 2012
Dalek flagship
Kap why do you run different cpu speeds for amd and nvidia, shouldn't you do them both at the same speeds, 4ghz or 4.4ghz on your 6950x
At those fps it won't make any difference.
If you overclock a CPU and it does not need it you can actually lower the score as the PC does not need it and it can lead to inefficiency.
Running a CPU @4.0 instead of 4.4 is not a factor when the GPU is only managing 29fps.
Here is an example of what I mean,
This is what I used for the bench thread
RX 480 @1380/2200
6950X @4.0
16.9.2 Drivers
1080p
DX11
And here is the same settings but with the CPU @4.4
18 Feb 2015
GTX 1060. Kaap, would it be possible to bench once with more normal settings and see how much you need to drop in order to achieve 60fps with the 1060?
31 Dec 2007
The TARDIS, Wakefield, UK
GTX 1080 @ GPU 2151/MEM 2628
i7 6700k @ 4.5ghz
372.90 drivers
DX12
1080p @ 94.8fps
1440p @ 75.8fps
9 Mar 2015
Earth
GTX 1080(s) Single Card tests: 2100/2725 -- SLI: 2050/2725
i7 5960x @ 4.6GHz
372.70 drivers
1080p
DX11
78.2 fps Average
DX12
66.8 fps Average
SLI - DX11
122.6 fps Average
3440 x 1440
DX11
38.8 fps Average
DX12
32 fps Average
SLI - DX11
70.2 fps Average
I expect our results with SLI 1080p resolution is as close as they are as there is a CPU bottleneck at that point. My 5960x was maxed out on a core and no doubt likely the case with your 6950x which explains how the 1080's even slightly behind your Pascal TX's come that close to one another.
Would be neat to see a Skylake 6700k OC'd with a Titan X Pascal SLI or 1080 SLI and see how that fares and if its better IPC helps.
Man of Honour
OP
21 May 2012
Dalek flagship
i7 5960x @ 4.6GHz
372.70 drivers
1080p
DX11
78.2 fps Average
DX12
66.8 fps Average
SLI - DX11
122.6 fps Average
3440 x 1440
DX11
38.8 fps Average
DX12
32 fps Average
SLI - DX11
70.2 fps Average
It is a very bad bottleneck @1080p with 2 cards.:)
Scoreboard updated.:)
Man of Honour
OP
21 May 2012
Dalek flagship
Not for the scoreboard
Stock FE 1060
6950X @4.0
372.90 Drivers
1080p
Settings - no AA gets it over 60fps
1080p
