xfi xtreme music or Asus Xonar U5 5.1 USB for Sennheiser PC 350 SE
2 Oct 2006
Currently have Asus Xonar U5 with my laptop and xfi xtreme music with my desktop PC.
To be honest I can rarely be bothered to get the Asus Xonar U5 out the laptop bag. Just wondering if I should leave it permanently set up with my desktop PC as a replacement for my old xfi xtreme music?
Will it be an upgrade? Headphones are Sennheiser PC 350 2015 Special Edition 150 Ω
Thanks! :)
Man of Honour
13 Oct 2006
If its a proper X-Fi Xtreme Music it'll be hard to beat unless you spend a fair bit on the latest and greatest.
OP
2 Oct 2006
I don't understand: you have the U5 and you have the X-Fi - why can't you use your ears to answer your own question? :D
I work away from home 5 days a week and don't have my desktop with me haha, sitting in the hotel room and wondering if there was a clear obvious answer.
The Xonar has a high impedance setting which I don't recall ever seeing on my xfi...also the xonar is out of the case (less noise?).
25 Jul 2012
Ankh Morpork
Fair answer :D
The impedance setting just adjusts the gain, so it can be used with both low and high impedance headphones / earphones. What it doesn't do is change the output impedance (~20ohms), so even though a low impedance headphone will play without too much noise, the sound quality "may" suffer depending on whether the headphone is sensitive to damping factor.
Even though your card is pretty ancient, it probably still holds up well against the U5 as those things were very impressive when they were first released and sound card tech hasn't really moved too far since.
OP
2 Oct 2006
Thanks for the explanations :) Guess I'll keep the U5 with the laptop and xtreme music with the PC then.
One last question, to help power the headphones from the xtreme music sound card will something cheap like a "Behringer MA400 Monitor Headphone Amplifier" or "Behringer HA400 Microamp 4 Channel Stereo Headphone Amplifier" do the job?
OP
2 Oct 2006
Think I've answered my own question. Cheap mains powered (non DAC) headphone amplifiers don't really exist at this budget they are all battery powered portables.
From googling the closest thing I'm looking for is SMSL sApII TPA6120A2 at £50!
25 Jul 2012
Ankh Morpork
Neither of the Behringers are suitable.
The SMSL will do what you want, the TPA6120A2 is the same amplifier driver chip as used in the Xonar STX, which is certainly not short of power.
Man of Honour
13 Oct 2006
I've been quite tempted to make up a PCB for it lately - a high quality basic desktop powered headphone amp can be built around a pretty simple circuit - especially if you use an AC adapter like the basic SMSL amps.
OP
2 Oct 2006
Interesting. Done a google for TPA6120A2 and came across the chips, circuit boards etc. Don't doing it myself :p but I have found this on ebay
"H9 Digital HIFI Earphone Amplifier TPA6120A2 Chip + Adapter Plug + Power Supply" £33 :0 that's more what I'm talking about only negative is it's shipped from china but at least I know now reasonably cheap does exist :)
Man of Honour
13 Oct 2006
Unfortunately I don't have the disposable income these days, £50 is too much for slightly more punchy sound. Especially when I thought I could do it for about £20 :p
I won't tell you how much I've spent since first deciding to replace my old headphone amplifier :| its more than £50.
