Time Spy Standard DX 12 Bench.
Caporegime
20 May 2007
Surrey
Just upgraded to a 1080 from my 1070 as I have gone 1440p now and found a good deal on a gaming x 1080
New score
http://www.3dmark.com/3dm/15412621
5820k at 4.3ghz
32gb 2400mhz ram
This 1080 boosts and holds at 1962hz out of the box
My old 1070 boosted to ~2ghz out of the box so similar core clocks (1070 slightly more) and this graphics score puts the 1080 at pretty much bang on 20% faster as expected, clock for clock.
28 May 2007
Score 8 691
AMD Radeon RX 480(2x) @1380/2200
Intel Core i7-6950X @4.4
Graphics Score 8 276
CPU Score 12 143
16.10.2 Drivers
http://www.3dmark.com/3dm/15679696?
Get the voltage pushed. Winter is just about here so even on air you could push 1.25 and most likely achieve higher clocks. This is OCUK after all. It's becoming a lot more common since voltage control was released to see these cards at over 1400mhz at 1.25v. On water people are pushing out 1.35v at around 1500mhz and above. If they explode you can always fall back on your vast array of monsters.
