Nitro Concepts s300 broken base
30 Jan 2008
I've got a the above s300 and have a similar issue to the one discussed here:
https://forums.overclockers.co.uk/posts/35056730/
In that the gas strut has forced its way through the base, but in my case the base appears to be split. I contacted Nitro and they came back (very quickly) that they had no spares at the moment.
Now I could've sworn I bought it from OC but I can't find an order number against it, so that's annoying, but my question is:
are bases freely 'interchangeable' for example, could I just use this one:
https://www.amazon.co.uk/Mastery-Mart-Office-Replacement-Diameter/dp/B07ZY36NJ1?th=1
rather than be forced to buy a whole new chair?
6 Nov 2005
So long as the hole is the right size it should be fine. they've listed the size as 5cm on that link. so maybe just measure your seat to see how it looks.
OP
30 Jan 2008
I completely missed that so thank you! I quickly measured and the main section is 5cm wide with a 4.5cm section at the base where it clearly is used to be inserted. Time to order. I'll come back with feedback in case anyone else has a similar problem
27 Jun 2006
Not here
This just happen to mine :mad:
Did the base fit?
