MSI's X570 Tomahawk May Become Go-To OC Board??
7 Oct 2003
York
Not sure about 5600X (or other cpus as EDC may be different), but on 5900X since AGESA 1.2.0.5 EDC is limited to 140. If you set EDC higher than 140 then boost voltage is throttled and max clocks suffer.
Btw @SpudMaster, our join dates and post counts are weirdly similar :D
30 Mar 2010
I bought this shortly after it came out and have a 8 core 3 series ryzen in it.
Whats the sweet point at this time for upgrading the CPU, that won't break the bank and the mobo is compatible with ?
26 Feb 2004
Hampshire, England.
Hi guys,
Just tried to flash to the latest bios and now my rig won't boot... fans spin and my keyboard lights up but thats it.
I left the room while the update was taking place but I can't imagine anything untoward happened?
I've never used the recovery method before, can someone here who has possibly guide me?
Thanks!
22 Mar 2008
If i remember correctly, i did the bios flashback once before with all components installed and am sure the led was white.
Have you tried resetting CMOS, it sometimes needs to be done.
  • Like
Reactions: JRS
