A bit of a delay between flash and bang...but I said I'd update thread, and then life happened.
I ended up looking at a number of different cars after my last post; BMW 5 series Tourings (I really didn't want another 3 series, i've worked out over 20 years i've had 4, each progressively worse imo but ymmv) and Audi A6 estates primarily. As after years living with a saloon, I felt the need for something with more room. The BMWs although I love them, were (at least the ones in my budget (early 30s for a AUC) pretty much base spec or the only extra were wheels and the Audis didn't seem to drive any better than what I ended up with, and also both marques were usually at least 3 years old or thereabouts.
So, I ended up with an approved used VW Arteon R-Line 200 diesel Shooting Brake, 10 months old (at purchase) and 8k on the clock, 2 years free servicing and 2 years manufacturer warranty extended in the deal for a further 1 year and a few other bits. Extras over base R-Line spec (at least what is important enough to remember) are nappa leather and ergo comfort massage seats, a full size spare and rear camera. It has the VW Travel Assist as standard as well as the usual Airplay/Android Auto (some of the BMWs I looked at only had Airplay) etc. I bought this early September, and paid less than a comparable Skoda Superb Estate (which I also looked at and wasn't enamoured with, the cabin and fit and finish on the Arteon is far better put together and has a quality feel, which seemed to command a higher premium (at least at the time I was looking) though being a cheaper car to purchase new and not as refined, which i found odd.
After 8 months and 7k miles (and after going through a wet winter), I think it is great for my usage (commuting, a round trip of 110 miles when I go to the office which is almost all motorway, chucking a bike in the back and moving an older kid around the country utilising the boot space (a glorified van essentially)). Not going to lie, but after looking at a sea of black or grey BMWs and Audis (and VWs and Skodas to be fair) I think the recent pic below will explain what sold it to me:
Although I was initially hesitant of the capacitive controls, after a while I haven't give them a thought, that is one thing I think is hyperbole, although I did miss the BMW dial controls for the infotainment, as it is just so intuitive. Additionally, the driving style after using a ZF gearbox for over a decade (this has a DSG) is quite different and has it's own foibles but isn't worse per se on this model.
Yes, it is a blue fridge diesel. But I like it's looks, it does it's job and with no fuss. I'm happy.
NB. Yes, I know the drive needs cleaning, but it seemed (and was iirc) like the first nice weekend of the year
![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
and it is on the list to do.
Edit for extra detail not included above: Standard equipment is very generous for VW, as this is supposed to be their more luxury model. One thing I should have mentioned above, is that it is also quieter (road noise) than a BMW 3 series (the last F30 330d I had I carried ear protectors for some sections of motorway) and dare I say it than a 5 (comparing from a F10 on 17s) though only by a little and may be explained by runflats, it is also much quieter than a Skoda Superb Estate. For balance, things I don't like are fake exhausts and for sheer solidity I liked my F10's interior though I didn't feel the same way about the G31.
